    RPi MM clientonly on Boot
    4 Posts 2 Posters 643 Views 2 Watching
    • E
      eguy6
      Hello! I have my MM server running on my homelab machine in a container just fine, but I’m using my RPi 3 to run the screen elsewhere in the room, so I only need the client running. It also runs Octoprint for my 3D printer since it’s right there too. Right now, the pi boots and starts MM in the default server mode and I would have to manually run
      node clientonly --address 192.168.1.5 --port 8080
      to get the client window with my server’s config. Even then, the original server window just reopens in the background when closed. My goal is to trim down resource usage, so ideally I can just boot into client mode. I remember this as part of the setup when I installed it via Docker for the server but it was not given as an option and I don’t know which files to change to force this.
        sdetweil @eguy6
        @eguy6 sounds like you used the scripted install to put MagicMirror on the pi. And selected pm2 to start
        If so, just edit the
        ~/MagicMirror/installers/mm.sh
        And put your client start command there instead of the
        npm start
        Used to start the full version
        S E 2 Replies Last reply Reply Quote 0
          pm2’s job is the start and keep the app running
          So when you close the window, ctrl-q,
          pm2 just restarts the app
          • E
            eguy6 @sdetweil
            @sdetweil Thank you, that worked perfectly! Now I just need to eliminate as many nonessential programs in the background. The flip clock and scoreboard scrolling are a bit choppy…
