    install/upgrade scripts updated to detect and use NVM
    3 Posts 2 Posters 931 Views 2 Watching
      sdetweil
      I am seeing more cases where users have used nvm to change their node version.
      which conflicts with the tool the scripts use (n, which is a nodejs version of nvm)
      but the two tools store the node versions in different places, which causes failures on update and install
      I have updated the tools to detect if nvm is installed and use it
      otherwise use n
      keep an eye out for any install or upgrade issues related to nodejs version
      thanks for any feedback
      • S sdetweil marked this topic as a regular topic on
        schlomm @sdetweil
        @sdetweil Thanks for your effort! For my Magic Mirror Instances I try to use/install the node version installed by MagicMirror, but yeah -“nvm” ist a great tool in the node ecosystem.
        Thanks for your work and the updates script ♥️
          sdetweil @schlomm
          @schlomm said in install/upgrade scripts updated to detect and use NVM:
          that is what the script does… reads package.json engines, and uses that.
          on some systems, you might get 22.20.0 instead of 22.18.0
          you don’t have to do it manually , as the script will handle it.
          BUT if you used nvm for some reason, then it puts code in the users home folder/.nvm
          and first in the PATH…
          n puts code in /usr/local/bin , but if nvm is first… oops…
          so , n did its thing, but no change…
          use the tool the user picked, quite a pain to get nvm to run FROM a script…
