    My module stops MMM-Pages working
    13 Posts 2 Posters 2.0k Views 2 Watching
      Scott-M
      My MagicMirror was working well, MMM-CalendarExt3 taking up the most of the display and fixed with MMM-Pages.
      The clock & weather at the top on page0 and some bus timetables on page1 and these switch around with the calendar being static.
      I was never happy with the way the bus times displayed and after lots of tweaking of the module I was using I decided to write my own to do what I wanted. It works and does what I want but MMM-Pages does nothing with my module active, all the modules are displayed all the time. If I disable my module, it all works as it should.
      I hadn’t noticed until now because I was working on it with only my module in the config.
      I know I have not posed any code or much detail yet but can if I have an idea of what would be useful. I can update here rather than paste pages of possible unrequired code now.
      This is my first attempt at writing a module, or anything in JS! so it has been a slow process. If there is something basic that I have not done that MMM-Pages requires then that is a good start.
        sdetweil @Scott-M
        @Scott-M Pages is done all in browser, so open the developers window, ctrl-shift-i, and select the console tab
        put pages in the filter field and see if there are any errors…
        are you using the original pages or my fork?
          Scott-M @sdetweil
          I seem to have lost the connection to my remote pi so will have a look tomorrow when I get my hands on it
          I think it is the original pages, will have a look at the fork
            sdetweil @Scott-M
            @Scott-M on which pages source no need to change , just asking for later debug purposes
              Scott-M @sdetweil
              There are no errors or issues in the console for MMM-Pages but what I didn’t see when my module is active is
              [MMM-pages] received that all objects are created; will now hide things!
              Which is present in the console when I disable it. I notice in the Pages docs it says
              MMM-pages doesn't activate until we receive the DOM_OBJECTS_CREATED notification, as that notification ensures all modules have been loaded.
              That is obviously not happening when my module is active. it loads the data from the NextBus API asyncronously so I think updateDom() keeps running before the first ready DOM is returned. I manually notifyied MagicMirror that it is ready by adding this into socketNotificationRecieved and seems to work now.
              if (!this.hasSentDomCreated) {
                      this.hasSentDomCreated = true;
                      this.sendNotification("DOM_OBJECTS_CREATED");
              There is probably a better way to do this but seems to work.
              This is my first attempt at a module so I wasn’t expecting plain sailing but any feedback is always appreciated.
              MMM-TravelLine.js
              // LCARS Colours
              var busColours = [
                "#cc99ff", //african-violet
                "#ffaa90", //almond
                "#ffbbaa", //almond-creme
                "#5566ff", //blue
                "#8899ff", //bluey
                "#ff9966", //butterscotch
                "#ffaa00", //gold
                "#ff9900", //golden-orange
                "#666688", //gray
                "#999933", //green
                "#99ccff", //ice
                "#cc55ff", //lilac
                "#cccc66", //lima-bean
                "#cc5599", //magenta
                "#ff2200", //mars
                "#9966ff", //moonlit-violet
                "#ff8800", //orange
                "#ff8866", //peach
                "#cc4444", //red
                "#aaaaff", //sky
                "#f5f6fa", //space-white
                "#ffcc99", //sunflower
                "#ff5555", //tomato
                "#ddbbff", //violet-creme
                // Lower Decks
                "#ffeecc", //butter
                "#ff9911", //daybreak
                "#ffaa44", //harvestgold
                "#ffcc99", //honey
                "#ff4400", //october-sunset
                "#ff7700", //orange
                "#cc5500" //rich-pumpkin
              function newColour () {
                  var randomNumber = Math.floor(Math.random() * busColours.length);
                  return randomNumber;
              const directionColours = {
                "Edinburgh, Bus Station": "#cc99ff",          //
                "Galashiels Transport Interchange": "#ff7700" // blue
              // fallback colour if direction not in map
              const defaultColour = "#cc9bcd";
              Module.register("MMM-TravelLine", {
                defaults: {
                  apiBase: 'https://nextbus.mxdata.co.uk/nextbuses/1.0/1',
                  username: "yourusername",
                  password: "yourpassword",
                  // stopIDs[[stop ID, Name for heading, target bus, Random colours or not]]
                  stopIDs: [  ["36235972","Princes St West (PD)","34",true],
                              ["36232486","The Mound (MD)","27",true]],
                  //targetBus: "X62",     // Service we’re interested in
                  updateFrequency: 10,   // Refresh time in minutes
                  maxResults: 10,
                  debug: false,
                getStyles() {
                  return ["travelline.css"];
                start() {
                  // some dummy values
                  this.timesReturned = [
                    {aimed: "..." ,service: "Error", direction: "...", raw: ""},
                  this.sendSocketNotification("FETCH_ROUTES", {
                    username:this.config.username,
                    password:this.config.password,
                    apiBase:this.config.apiBase,
                    stopIDs:this.config.stopIDs,
                    //targetBus:this.config.targetBus,
                    timestamp: new Date().toISOString(),    // Build a fresh ISO8601 timestamp
                  // Fetch new routes at the interval set in the config
                  setInterval(() => this.sendSocketNotification("FETCH_ROUTES", {
                  }), this.config.updateFrequency * 60 * 1000);
                  // Refresh the display every 30 seconds
                  setInterval(() => this.updateDom(), 30000);
                notificationReceived(notification, payload) {
                  if (notification === "UPDATED_ROUTES") {
                    this.timesReturned = payload;
                    //this.updateDom();
                socketNotificationReceived: function (notification, payload) {
                    this.updateDom();
                    // Notify once that DOM objects exist
                getDom() {
                  const container = document.createElement('div');
                  container.className = 'travelline-container';
                  container.style.display = 'flex';           // show tables side-by-side
                  container.style.gap = '20px';               // spacing between tables
                  //console.log("timesReturned is: ",this.timesReturned)
                  // show message until we have data
                  if (!Array.isArray(this.timesReturned) || this.timesReturned.length === 0) {
                    container.innerHTML = "<div class='no-data'>Loading bus times…</div>";
                    return container;
                    // loop through each stop’s departures
                    this.timesReturned.forEach((stopResults, stopIndex) => {
                      const resultsArray = Array.isArray(stopResults) ? stopResults : [];
                      // create a wrapper for this stop
                      const stopWrapper = document.createElement('div');
                      stopWrapper.className = 'stop-wrapper';
                      // optional: heading for the stop
                      const heading = document.createElement('h3');
                      heading.className = "travelline-heading";
                      heading.textContent = `${resultsArray[0].stopName}`;  //heading.textContent = `Stop ${stopIndex + 1}`;
                      //heading.style.textAlign = 'center';
                      stopWrapper.appendChild(heading);
                      //if (!(stopResults[stopIndex].direction == "No Departures")) {
                      // create table
                      const table = document.createElement('table');
                      table.className = 'travelline-table';
                      // limit results
                      const limitedResults = resultsArray.slice(0, this.config.maxResults);
                      limitedResults.forEach(item => {
                        if (!(item.direction == "No Departures")) {
                          const row = document.createElement('tr');
                          row.className = 'travelline-row';
                          if (item.randomColour){
                            const colourIndex = newColour();
                            row.style.color = busColours[colourIndex];
                          } else {
                            // Pick a fixed colour based on destination direction
                            const dir = item.direction.trim();
                            row.style.color = directionColours[dir] || defaultColour;
                          // minutes-to-departure
                          const minutesCell = document.createElement('td');
                          minutesCell.className = 'travelline-minutes';
                          const depTime = new Date(item.raw);
                          const diffMs = depTime - Date.now();
                          const diffMin = Math.max(0, Math.round(diffMs / 60000));
                          if (diffMin >= 60) {
                            const hours = Math.floor(diffMin / 60);
                            const mins  = diffMin % 60;
                            minutesCell.textContent = `(${hours}h ${mins}m)`;
                          } else {
                            minutesCell.textContent = `(${diffMin} m)`;
                          // aimed departure time
                          const timeCell = document.createElement('td');
                          timeCell.className = 'travelline-time';
                          timeCell.textContent = item.aimed;
                          // service
                          const serviceCell = document.createElement('td');
                          serviceCell.className = 'travelline-service';
                          serviceCell.textContent = item.service;
                          // direction
                          const directionCell = document.createElement('td');
                          directionCell.className = 'travelline-direction';
                          directionCell.textContent = "To " + item.direction.replace(/,/g, "").split(" ")[0];
                          // assemble row
                          row.appendChild(minutesCell);
                          row.appendChild(timeCell);
                          row.appendChild(serviceCell);
                          row.appendChild(directionCell);
                          table.appendChild(row);
                        } else {
                          //Set row to a random colour
                          // direction - should display'No Departures for the '
                          directionCell.textContent = item.direction + " for the ";
                          // service
                          // assemble row
                      }); //limited results end
                      stopWrapper.appendChild(table);
                      container.appendChild(stopWrapper);
                  return container;
              node_helper.js
              const NodeHelper = require("node_helper");
              //const fetch = require("node-fetch");	// Ensure fetch is available
              const { URL } = require("url"); 		// Ensure URL is available
              const { parseStringPromise } = require("xml2js");
              	async socketNotificationReceived(notification, payload) {
              		console.log(`There are ${payload.stopIDs.length} stop IDs in the array`);
              		if (notification === "FETCH_ROUTES") {
              			try {
              				const authHeader = "Basic " + Buffer.from(`${payload.username}:${payload.password}`).toString("base64");
              				const siriBodies = this.buildSiriBodyArray(payload.stopIDs, payload.username, payload.timestamp);
                  			// store results for all stops
              				const allResults = [];
                  			// loop over each stop body
              				for (const [index, siriBody] of siriBodies.entries()) {
              					//console.log("siriBody is: ", siriBody[0]);
              					try {
              						const response = await fetch(payload.apiBase, {
              							method: "POST",
              							headers: {
              								"Content-Type": "application/xml",
              								"Authorization": authHeader
              							body: siriBody
              						if (!response.ok) {
              							console.error(`Fetch failed for stop ${payload.stopIDs[index][0]}: ${response.status}`);
              							continue;
              						const xmlText = await response.text();
              						const result = await parseStringPromise(xmlText, { explicitArray: false });
                      				// extract departures for this stop. stopIDs [stopID, StopName, target bus, randomColours]
              						let times = this.getTimes(result, payload.stopIDs[index]);
              						console.log("times is", times)
              						if (times[0] === "No Departures"){
              							console.log("Times returned and no departures or target bus not found");
              							const theService = times[1]
              							const theStop = times[2];
              							times = [{
              								service: theService,
                  							direction: 'No Departures',
                  							aimed: 0,
                  							raw: 0,
                  							stopID: '',
                  							stopName: theStop,
                  							randomColour: true
                      				allResults.push(times); // Removed spread operator to seperate the data from each stop
                      			} catch (err) {
                      				console.error(`Error fetching stop ${payload.stopIDs[index][0]}:`, err);
                  			// finally send combined result
                      		//console.log(allResults);
                      		this.sendSocketNotification("UPDATED_ROUTES", allResults);
                      	} catch (error) {
                      		console.error("General fetch error:", error);
                  getTimes: function(receivedData, stopID) {
                  	const departures = receivedData?.Siri?.ServiceDelivery?.StopMonitoringDelivery?.MonitoredStopVisit;
                  	if (!departures){
                  		console.log("No departures found at this stop");
                  		return ["No Departures",stopID[2], stopID[1]];	// return 'No Departures', bus name, stop name
                  	const departuresArray = Array.isArray(departures) ? departures : [departures];
                  	const myBus = departuresArray.filter(d => d.MonitoredVehicleJourney?.PublishedLineName === stopID[2]); //target);
                  	if (myBus.length === 0) {
                  		console.log("No target bus found at this stop");
                  	return myBus.map(d => {
                  		const call = d.MonitoredVehicleJourney.MonitoredCall;
                  		const rawTime = call.ExpectedDepartureTime || call.AimedDepartureTime;
                  		const dateObj = new Date(rawTime);
                  		const isValidDate = rawTime && !isNaN(dateObj.getTime());
                			const friendlyTime = isValidDate
                  			? dateObj.toLocaleTimeString('en-GB', {
                  				hour: '2-digit',
                  				minute: '2-digit'
                  			: "N/A";
                  		return {
                  			service: stopID[2],		// target bus,
                  			direction: d.MonitoredVehicleJourney.DirectionName,
                  			aimed: friendlyTime,
                  			raw: rawTime,
                    			stopID: stopID[0],		// stopID
                    			stopName: stopID[1],	// Description or stop name for the table heading
                    			randomColour: stopID[3]	// Random colour
                  buildSiriBodyArray: function(stopIDs, username, timestamp){
                  	if (stopIDs.length == 0) {
                  		console.log("The stopID array is empty");
                  		return undefined;
                  	const siriBodys = [];
                  	stopIDs.forEach((item, index) =>{
                  		siriBodys.push(`<?xml version="1.0" encoding="UTF-8"?>
              				<Siri version="1.0" xmlns="http://www.siri.org.uk/">
               					<ServiceRequest>
                  					<RequestTimestamp>${timestamp}</RequestTimestamp>
                  					<RequestorRef>${username}</RequestorRef>
                  					<StopMonitoringRequest version="1.0">
                    						<MessageIdentifier>msg-001</MessageIdentifier>
                    						<MonitoringRef>${item[0]}</MonitoringRef>
                  					</StopMonitoringRequest>
                					</ServiceRequest>
                  	</Siri>`);
                  	return siriBodys;
                sdetweil @Scott-M
                @Scott-M you dont tell MagicMirror you are ready, it tells you
                You wait for ALL_MODULES_STARTED
                You can start operations in start()
                Do whatever, but you can’t draw yet
                getDom() will be called for your content the first time
                You never SEND any of those notifications
                sendNotification is a broadcast to all other modules,
                MagicMirror doesn’t receive it
                https://github.com/sdetweil/SampleModule
                See my sample module
                S S 2 Replies Last reply Reply Quote 0
                  The only notice you can provide is calling updateNotification to inform MagicMirror that your module has new content to display
                  AND Only after ALL_MODULES_STARTED, and After the first getDom() call
                    Scott-M @sdetweil
                    @sdetweil said in My module stops MMM-Pages working:
                    You are absolutely correct, I should have properly read about the life cylce of MagicMirror first.
                    I changed socketNotificationRecieved to
                          this.loaded = true;
                          this.updateDom();
                    and added this in getDom()
                        if (!this.loaded) {
                          return container;
                    I think the module made updateDom() call before returning a valid DOM the first time. Let me know what you think! This also works now…
                      sdetweil @Scott-M
                      @Scott-M not quite…
                      i avoid this state setting (this.loaded) by always waiting til ALL_MODULES_STARTED
                      before asking my helper to work, then I KNOW its good on socketNotificationReceived to use updateDom
                      notificationReceived: function(notification, payload, sender) {
                      		// once everybody is loaded up
                      		if(notification==="ALL_MODULES_STARTED"){
                      			// send our config to our node_helper
                      			this.sendSocketNotification("CONFIG",this.config)
                      note: you CAN still get getDom() called BEFORE your socketNotification has been called by your node_helper sending data
                      so you need to check for data and return an empty DIV… (getDom MUST return SOMETHING)
                        Scott-M @sdetweil
                        I think I understand, am I getting closer with something like this:
                          start() {
                            this.timesReturned = [];
                          notificationReceived(notification, payload, sender) {
                            if (notification === "ALL_MODULES_STARTED") {
                              console.log("All modules started; fetching routes now");
                                username: this.config.username,
                                password: this.config.password,
                                apiBase: this.config.apiBase,
                                stopIDs: this.config.stopIDs,
                              // Schedule refresh
                              setInterval(() => {
                              }, this.config.updateFrequency * 60 * 1000);
                              this.updateDom();
                          getDom() {
                            const container = document.createElement("div");
                            container.className = "travelline-container";
                              return container;
                            // ...builds table etc.......
                            return container;
                        Again, I have lost my remote conection to the PI so I can’t try it until tomorrow!
                          sdetweil @Scott-M
                          @Scott-M said in My module stops MMM-Pages working:
                          yes, looks good…
                          container.className = “travelline-container”;
                          you don’t have to set a class on the wrapper/container,
                          as MagicMirror has set your module name as a class on the module entry
                          open the developers window, and examine the html layout for a module in the elements tab
                          see the second link in my signature below
                            Scott-M @sdetweil
                            @sdetweil Great, will hopefully get my mirror on the wall next week!#
                              sdetweil @Scott-M
                              @Scott-M awesome!
