    Issues with MMM-Screen-Powersave-Notification
    12 Posts 4 Posters 1.0k Views 4 Watching
    • mumblebajM Offline
      mumblebaj Module Developer @Rags
      @Rags Hi. I am running Trixie since the beginning of the year. I wrote a post about setting up the screen stuff and monitor on and monitor off. See my post. When you turn on the monitor with a script you can set the resolution,
      https://forum.magicmirror.builders/topic/19116/having-trouble-with-screen-on-and-off-here-are-some-tips-that-could-help?_=1761576771063
        Rags @schlomm
        @schlomm ## I just thoght of uploading the Summary of Attempts - All Failed. It is really getting frustrating. My Monitor was working perfectly well the desired rotation and resolution 1080x1960, and now is stuck at 1024x768.
        1. config.txt modifications:**
        • Custom hdmi_timings for 1920x1080
        • Various hdmi_mode settings (82, 87)
        • hdmi_ignore_edid=0xa5000080
        • Different boost levels and drive settings
        • Result: Monitor only shows up to 1024x768 max
        1. cmdline.txt kernel parameters:**
        • video=HDMI-A-1:1920x1080@60D
        • Various video= parameter combinations
        • Result: No effect on available resolutions
        1. Custom EDID firmware:**
        • Created multiple EDID files (256 bytes, 268 bytes, 285 bytes)
        • Placed in /lib/firmware/edid/ and /boot/firmware/edid/
        • Used drm.edid_firmware=HDMI-A-1:edid/1920x1080.bin
        • Rebuilt initramfs to include EDID early
        • Result: Kernel loads file but rejects it as “Invalid firmware EDID”
        1. Wayland/X11 rotation scripts:**
        • wlr-randr (Wayland) - can’t set non-existent 1920x1080 mode
        • xrandr (X11) - output name issues
        • Result: Can only work with available modes (max 1024x768)
        Core Problem:
        • Acer HA270 monitor provides NO EDID data** to the Pi
        • Bookworm OS + Labwc Wayland compositor won’t accept forced resolutions
        • Same monitor worked with Pi 3B + Bullseye (older firmware stack)
        • Raspberry Pi detects only: 1024x768, 800x600, 848x480, 640x480
        Current Status:
        Stuck at 1024x768 rotated = 768x1024 instead of desired 1080x1920. Wonder if we the Rpi OS team is aware f this issue.
