    Docker Watchtower container restarting and mm container errors after upgrade
    9 Posts 3 Posters 1.4k Views 3 Watching
      scottwalsh
      Running magicmirroros which uses Karsten’s docker implementation.
      This morning found mm blank, and the mm container had sigfault errors connecting to the screen (didn’t collect logs). As been at last six months since last updated, updated the os (apt-get update/upgrade), containers, and rebooted.
      Everything looks to be running fine outwardly, however noted a few errors in the container logs.
      And the watchtower log is just in a loop restating.
      Extracts below.
      scottwalsh@calendar:/opt/mm/run $ docker logs mm
      [2026-01-02 07:59:07.394] [LOG]   [app] Server started ...
      [2026-01-02 07:59:07.397] [LOG]   [node_helper] Connecting socket for: MMM-mmpm
      [2026-01-02 07:59:07.399] [LOG]   [node_helper] Starting module helper: MMM-mmpm
      [2026-01-02 07:59:07.401] [LOG]   [node_helper] Connecting socket for: calendar
      [2026-01-02 07:59:07.402] [LOG]   [calendar] Starting node helper for: calendar
      [2026-01-02 07:59:07.404] [LOG]   [node_helper] Connecting socket for: MMM-AVStock
      [2026-01-02 07:59:07.406] [LOG]   [node_helper] Connecting socket for: MMM-anotherNewsFeed
      [2026-01-02 07:59:07.408] [LOG]   [MMM-anotherNewsFeed] Starting node helper for: MMM-anotherNewsFeed
      [2026-01-02 07:59:07.409] [LOG]   [node_helper] Connecting socket for: updatenotification
      [2026-01-02 07:59:07.411] [LOG]   [node_helper] Starting module helper: updatenotification
      [2026-01-02 07:59:07.412] [LOG]   [app] Sockets connected & modules started ...
      [21:0101/185908.239072:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      [2026-01-02 07:59:08.641] [LOG]   [electron] Launching application.
      [21:0101/185909.015470:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
      [21:0101/185909.016371:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      [21:0101/185909.016913:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      [21:0101/185909.017979:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      [21:0101/185909.018861:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
      [21:0101/185909.023819:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
      [2026-01-02 07:59:12.566] [INFO]  [utils]
      scottwalsh@calendar:/opt/mm/run $ docker logs watchtower
      time="2026-01-01T18:58:38Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:38Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:58:43Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:43Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:58:46Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:46Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:58:50Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:50Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:58:54Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:54Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:58:58Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:58:58Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:59:04Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:59:04Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:59:13Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:59:13Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:59:27Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:59:27Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
      time="2026-01-01T18:59:55Z" level=error msg="Error response from daemon: client version 1.25 is too old. Minimum supported API version is 1.44, please upgrade your client to a newer version"
      time="2026-01-01T18:59:55Z" level=info msg="Waiting for the notification goroutine to finish" notify=no
        sdetweil @scottwalsh
        @scottwalsh what does the docker compose look like for watchtower?
        I know there have been stories about it not being maintained and breaking. But my uses still work.
        There are supposed replacements. People forked and fixed under other names
        What is is this docker stack running on?
        I just released the latest MagicMirror about 10am US central time today. Was this MagicMirror container failed before then?
        Looks like maybe docker needed update for the os updates?
        S karsten13K 2 Replies Last reply Reply Quote 0
          scottwalsh @sdetweil
          The docker stack is running on magicmirroros (https://gitlab.com/khassel/magicmirroros). Installed in May’24 from the provided image.
          Saw the new release was recently out. Not sure if failed before or after that.
          Noted it had failed 1pm US central time.
          Updated the OS and containers about 2pm US central time.
          Looking https://gitlab.com/khassel/magicmirror/-/pipelines - I think the containers might have been updated since the new release.
          scottwalsh@calendar:/opt/mm/run/includes $
          scottwalsh@calendar:/opt/mm/run/includes $ cat watchtower.yaml
          services:
            watchtower:
              privileged: true
              image: ${WATCHTOWER_IMAGE}
              container_name: watchtower
              volumes:
                - /var/run/docker.sock:/var/run/docker.sock
              # --interval 300 --> poll interval in seconds
              # --cleanup --> for auto image pruning
              command: --interval ${MM_WATCHTOWER_INTERVAL} ${MM_WATCHTOWER_CLEANUP}
              restart: always
            @scottwalsh @karsten13 will have to help
            MMOs is on pi os I think
            • karsten13K Online
              karsten13 @sdetweil
              there is a line
              WATCHTOWER_IMAGE="containrrr/watchtower:latest"
              in the file /opt/mm/run/.env.
              Can you change this to
              WATCHTOWER_IMAGE="ghcr.io/nicholas-fedor/watchtower:latest"
              and restart with
              cd /opt/mm/run
              docker compose up -d
              Background is that the original watchtower is unmaintained and I suspect the original image is to old now. The new image is from a maintained fork, I use this already in other setups.
                scottwalsh
                @karsten13
                Thank you for that. The Watchtower seems to be running fine now.
                Did you have any thoughts on these errors that appear in the mm container? Seems to be running fine.
                [Extract]
                [2026-01-02 14:09:18.082] [LOG]   [app] All module helpers loaded.
                [2026-01-02 14:09:18.105] [LOG]   [server] Starting server on port 8080 ...
                [2026-01-02 14:09:18.113] [WARN]  [server] You're using a full whitelist configuration to allow for all IPs
                [2026-01-02 14:09:18.226] [LOG]   [app] Server started ...
                [2026-01-02 14:09:18.229] [LOG]   [node_helper] Connecting socket for: MMM-mmpm
                [2026-01-02 14:09:18.231] [LOG]   [node_helper] Starting module helper: MMM-mmpm
                [2026-01-02 14:09:18.233] [LOG]   [node_helper] Connecting socket for: calendar
                [2026-01-02 14:09:18.235] [LOG]   [calendar] Starting node helper for: calendar
                [2026-01-02 14:09:18.236] [LOG]   [node_helper] Connecting socket for: MMM-AVStock
                [2026-01-02 14:09:18.239] [LOG]   [node_helper] Connecting socket for: MMM-anotherNewsFeed
                [2026-01-02 14:09:18.240] [LOG]   [MMM-anotherNewsFeed] Starting node helper for: MMM-anotherNewsFeed
                [2026-01-02 14:09:18.242] [LOG]   [node_helper] Connecting socket for: updatenotification
                [2026-01-02 14:09:18.243] [LOG]   [node_helper] Starting module helper: updatenotification
                [2026-01-02 14:09:18.245] [LOG]   [app] Sockets connected & modules started ...
                [21:0102/010919.030995:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
                [2026-01-02 14:09:19.430] [LOG]   [electron] Launching application.
                [21:0102/010919.848714:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
                [21:0102/010919.850527:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
                [21:0102/010919.852228:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
                [21:0102/010919.852910:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
                [21:0102/010919.860171:ERROR:dbus/bus.cc:408] Failed to connect to the bus: Failed to connect to socket /var/run/dbus/system_bus_socket: No such file or directory
                [21:0102/010919.860444:ERROR:dbus/object_proxy.cc:573] Failed to call method: org.freedesktop.DBus.NameHasOwner: object_path= /org/freedesktop/DBus: unknown error type:
                [2026-01-02 14:09:23.059] [INFO]  [utils]
                • karsten13K Online
                  karsten13 @scottwalsh
                  @scottwalsh said in Docker Watchtower container restarting and mm container errors after upgrade:
                  they are only noise, you can ignore them.
                  I thought I sorted out the dbus errors but they are back again, will update my setup so they disappear in the future.
                  • karsten13K Online
                    karsten13 @karsten13
                    I found a good documented PR in another project which explains the dbus errors in detail.
                      @karsten13 said in Docker Watchtower container restarting and mm container errors after upgrade:
                      Thanks for providing the link, interesting background.
                      • S scottwalsh has marked this topic as solved on
                      • karsten13K karsten13 referenced this topic on
