    Raspberry Pi 5 multiboot on nvme
    4 Posts 2 Posters 628 Views 2 Watching
    • RonaldR
      Ronald
      Hi there,
      Has anyone managed to get multiboot working on a Raspberry Pi 5 with NVMe? I’m having trouble with PINN, BerryBoot doesn’t work on RP5 either, and CahtGPT and Deepseek let me try all sorts of things, but I haven’t found a working solution.
        sdetweil @Ronald
        @Ronald you mean grub to pick different os’s?
        RonaldR 1 Reply Last reply
        • RonaldR
          Ronald @sdetweil
          @sdetweil,
          yes, I would like to have there instances, One with working MagicMirror, One for experimenting with different modules and One for general use. Also a datapartition, to use with all three instances and a startmenu to Switch between the instances.
            sdetweil @Ronald
            @Ronald ok, I only see pinn on sd card as a choice there
            On the MagicMirror topic you can use a different config.js with the
            MM_CONFIG_FILE
            environment variable
            So a different startup script would allow you to quickly switch between them
