SBC boards that work well besides Raspberry pi 3, 4 or 5
@plainbroke search mini pc
Here is a product on Amazon
https://a.co/d/8GDWFsX -
Ah, I actully have one of those, I was given.
Supposedly didn’t work just had a failed ssd in it.
replaced that and loaded win 11, works fine.
Maybe I should set it up to run some form of linux.
I think I will, thanks for the Idea… -
@plainbroke then backup your MagicMirror config w my scripts,
Install MagicMirror the restore w my scripts. Easy move -
@plainbroke I have been looking into expanding my horizons but I have a question that have not really seen discussed.
When I think PC, I think machine that you (the owner) is going to do multiple tasks with whether that is play high end games on at one end of the spectrum and a cheap laptop you can take traveling, check email, do some powerpoints on and do business related word processing stuff which is kind of where Windows roots lie.Flip side is Pi’s and Pi-like devices that in my case is running things like Pi-hole, MM, Raspberry Shake (earthquake detection, GPIO stuff but all are 1 SBC doing one thing.
Do people do multi-tasking on SBC’s in general? Since this question is about Home Assistant, are people using Mini-PC’s and running HA and browing the internet, email, and light duty stuff that one would do on a middle of the road PC or laptop
Why should I by a Nuc instead of a base model Pi5 or other Linux based SBC to Run HA.I’ve been eyeballing a LattePanda IOTA but I also already have a PC that doesn’t complain when I run Fusion or GIMP.
I have priced some of these mini-PC’s and they can get quite pricey -
@ankonaskiff17 you are doing multi tasking anytime you run more than one thing. Doesn’t have to be user input kind of thing(web browsing)
pi w MagicMirror and something else is the same as mini
@ankonaskiff17
I too am a single use per Pi person. 1 runs MM but with pages and 48 modules running on it. Pi4 8gb. 1 that is the homes DHCP server Pi4 2gb then I have one that is my DNS in house server Pi4 4gb 1 pizero running a backup dns the DHCP, DNS are all 3 on battery backup… I have a Pi3 that runs a photo show program that runs my pictures of My sons family I need to load a bunch new pictures. I also have a dedicated to my DEX Calendar LePotato. it is too slow for most anything else.
All serve their purpose very well. The Pi5 4gb to 16gb version to me is a slower PC than I use personally. But they are more than capable to run pretty much all the software you referenced… Would be cheaper than a mini / NUC.The mini aka fan less PC was a freebie. So I fixed it and run windows 11 on it but hardly ever actually use it. My laptop is my primary pc for use.
My Older windows 10 PC runs a LOT of my home related programs like cameras and laser engraver. It is my link to my 2 tb shared drive…I am an amateur at networking but I have a lot of fun playing with it all.
Have you played with Zorin-OS-18 yet? That is what I have been thinking of loading on the mini PC. -
@plainbroke I have not the latest Zorin. But tried the prior releases in a vm.
Different ui, but same oh otherwise
