    MMM-Pages is it possible to name the pages, i.e. weather, stocks, etc...
    Scheduled Pinned Locked Moved Forum
    5 Posts 2 Posters 2.5k Views 2 Watching
    • J
      JeanMichelC
      Hi, I am grouping modules by pages and wonder if it is possible to name each pages, like a header.
      For example, all the weather modules are under the weather pages, stocks, under stick, etc…
      S 2 Replies Last reply
        sdetweil @JeanMichelC
        @JeanMichelC using the classes approach you can name the page groups anything you like
        Page1
        Weather
        Mom
        Dad
        Stocks
        Whatever
        Then in each module config
        Add the
        classes:"Page1 Mom",
        List of pages this module should appear on
        The classes keyword goes with the module: property, outside the modules config:{…}. Section
        The string for classes is the space separated list of names
        If you want a module to appear on every page, then the name would be the nice name you use for the fixed: property in pages config. I call that “every_page”, cause it makes sense
          @JeanMichelC it doesn’t matter where the modules are listed in config.js. The classes property will group them
          MagicMirror can only show or hide modules. There is an api used by the pages module to find modules by class name.
          The module name or the page group name are both classes used by that spi
            From the pages doc
            J 1 Reply Last reply
            • J
              JeanMichelC @sdetweil
              @sdetweil Thanks, I made the changes ad it works perfectly. Thank you for your prompt response.
              Reply Quote 1
