    CustomText change contents with notification?
    4 Posts 2 Posters 240 Views 3 Watching
      snerk4000
      hey all. noob time.
      from their descriptions, using ModuleScheduler i should be able to change the contents of CustomText via a notification, but it’s a little unclear to me how this is supposed to work.
      what the docs seem to describe:
      {       module: "MMM-CustomText",
              position: "top_center",
                      initialMessage: "change with notification?",
                      uniqueID: "ct_event",
                      animationspeed: 1000,
      {       module: "MMM-ModuleScheduler",
                      notification_schedule: [ // sched = cron format
                              { notification: "CUSTOMTEXT_UPDATE", schedule: "33 * * * *", payload: { type: "notification", uniqueID: "ct_event", title: "test 1"}},
                              { notification: "CUSTOMTEXT_UPDATE", schedule: "34 * * * *", payload: { type: "notification", uniqueID: "ct_event", title: "test 2"}},
      which is clearly not correct because it does nothing, but i’m stuck as to why. any help is appreciated!
        sdetweil @snerk4000
        @snerk4000 and you have the schedule set to fire at 33 or 34 minutes after the hour
        Only once every hour for each, right?
        If you install MMM-Notifications you should able to see it.
        The payload looks ok. Doesn’t need the type: only the values the receiving module would accept/need
        You could try my MMM-CurlToNotification module to test the notification without schedule
        https://github.com/sdetweil/MMM-CurlToNotification
          snerk4000 @sdetweil
          @sdetweil right now the 33/34 mins were just for testing, it’s aiming to be more like an MOTD / “don’t forget to put the trash out tonight” sort of thing
            sdetweil @snerk4000
            @snerk4000 understood. I only mention that cause once an hour is hard to test
            Trying to give you other ways to test and verify
