    Default calendar module seems to disregard month when filtering recurring events.
    6 Posts 2 Posters 1.0k Views 2 Watching
      jpiatt
      I have a very out-of-the-box installation of the default calendar module on my mirror. But the mirror’s calendar shows that my brother’s birthday is this coming Monday, which is March 23. However, my iCal (the one referenced in my config) correctly indicates my brother’s birthday is December 23. This seems to occur for all my yearly recurring events.
      Anyone noticed this before? I’ve been running my mirror for a couple years now and I think this defect has been there for at least a year. I’ve just been too busy to look into it until now
      Thanks in advance for any advice.
      -Jerry
        sdetweil @jpiatt
        @jpiatt can you show the event from the iCal data
        curl -sL the cal_url > somefile.txt
        Edit somefile.txt and find the vevent for that
        Paste here w code block around
        You can change the title and any other thing that exposes you or your url. Don’t delete any lines
        There is a big rewrite of the calendar processing coming on April 1.
        You could test that now, see the troubleshooting section pinned topics on testing fixes
          jpiatt @sdetweil
          Thanks for your response. Below is the event from my calendar data. The result on the screen shows this event occurring on Monday (03/23/2026) when, as you can see the next occurrence is not until 12/23/2026.
          SUMMARY:James Birthday
          UID:SAVZ-07DB041D-0010-083A-FF32-00771
          X-MICROSOFT-CDO-BUSYSTATUS:FREE
          END:VEVENT
          BEGIN:VEVENT
          CREATED:20110429T085854Z
          DTEND;VALUE=DATE:20191224
          DTSTAMP:20241222T221632Z
          DTSTART;VALUE=DATE:20191223
          LAST-MODIFIED:20191223T081329Z
          RECURRENCE-ID;VALUE=DATE:20191223
          SEQUENCE:0
          END:VEVENT
          BEGIN:VEVENT
          DTEND;VALUE=DATE:20201224
          DTSTART;VALUE=DATE:20201223
          LAST-MODIFIED:20201222T184617Z
          RECURRENCE-ID;VALUE=DATE:20201223
          SEQUENCE:0
          END:VEVENT
          BEGIN:VEVENT
          DTEND;VALUE=DATE:20061120
          UID:SAVZ-07DB041D-0015-083A-FF31-00740
          EXDATE;VALUE=DATE:20201119
          DTSTAMP:20231119T211712Z
          SEQUENCE:0
          CLASS:PRIVATE
            sdetweil @jpiatt
            @jpiatt because there are multiple vevents with the same UUID, AND NO rrule, this says the actual event has been expanded somewhere… are you using MMM-CalDav??
            if so, please change the server side property
            expand	true
            to false
              jpiatt @sdetweil
              @sdetweil Thanks, Sam. I don’t use MMM-CalDav. But it has occurred to me that there may be some corruption in my calendar data (heaven knows how many years ago I created these entries) so I’m going to test by deleting a couple of yearly events and recreate them to see if that fixes the problem.
                sdetweil @jpiatt
                @jpiatt ok, let us know.
                Big calendar rewrite coming next Wednesday
                My cal is 12 yrs old, oops actually 17 yrs.
