    MMM-ModuleScheduler: need help
    Scheduled Pinned Locked Moved Showcase
    13 Posts 2 Posters 4.8k Views 2 Watching
      anagallis
      Hello,
      I need help to use the MMM-ModuleScheduler,
      I don’t know how to config this module to display other modules at chosen times.
      My need is to display picture module witch display different pictures on different times. Actually I use MMM-RandomPhoto, because I can configure a path with pictures.
      I want to display pictures from the path:
      • ‘MondayMorning/’ on monday morning from 9h00 to 12h00
      • ‘Mandayafternoon/’ on monday from 13h00 to 17h00
      • ‘thuesdaymorning’ on thuesday form 9 to 12, etc…
      I can’t understand how to do that… is there somebody to help me please?
        sdetweil @anagallis
        @anagallis if the schedules are the same every day, the easiest way would be the global schedule
        Use the crontab tool to create a schedule line from:to for each time period, and add a string for the global_scheduler classname.
        Then on the picture module add a property
        classes:"???? ?????"
        Where ??? Is the classname you specified in the schedule definition.
        These classnames are just arbitrary strings, for example
        Morning_scheduler, afternoon_schedule
        The classes property takes a list of space separated strings
        If the schedules are different on different days,
        Make a pair for each day, using the same schedule names for all the days
          anagallis @sdetweil
          Many thanks @sdetweil ,
          Here is what I done, and MM only displays pictures from the first MMM-RandomPhoto, the class ‘lundimatin’ and we’re mondy afternoon, not morning…
                      module: 'MMM-ModuleScheduler',
                          // SHOW MODULES WITH THE CLASS '*********' AT **:00 AND HIDE AT **:00 EVERY DAY
                          notification_schedule: [
                          // SHOW AN ALERT toutes les minutes impairs
                          {notification: 'SHOW_ALERT', schedule: '1-59/2 * * * *', payload: {type: "notification", title: 'Impaire !'}},
                          // SHOW AN ALERT toutes les minutes pairs
                          {notification: 'SHOW_ALERT', schedule: '*/2 * * * *', payload: {type: "notification", title: 'Paire !'}},
                          // SHOW MODULES WITH THE CLASS 'lundimatin' AT 09:00 AND HIDE AT 13:00 EVERY LUNDI
                          {from: '0 9 * * *', to: '0 13 * * 1', groupClass: 'lundimatin'},
                          // SHOW MODULES WITH THE CLASS 'lundiaprem' AT 14:00 AND HIDE AT 17:00 EVERY LUNDI
                          {from: '0 14 * * *', to: '0 17 * * 1', groupClass: 'lundiaprem'},
                          // SHOW MODULES WITH THE CLASS 'mardimatin' AT 09:00 AND HIDE AT 13:00 EVERY MARDI
                          {from: '0 9 * * *', to: '0 13 * * 2', groupClass: 'mardimatin'},
                          // SHOW MODULES WITH THE CLASS 'mardiaprem' AT 14:00 AND HIDE AT 17:00 EVERY MARDI
                          {from: '0 14 * * *', to: '0 17 * * 2', groupClass: 'mardiaprem'},
                      module: 'MMM-RandomPhoto',
                      position: 'fullscreen_below',
                      classes: 'lundimatin',
                          imageRepository: "localdirectory",
                          repositoryConfig: {
                              path: "/home/pi/MagicMirror/modules/Images/lundimatin/",
                              recursive: true,
                              exclude: ["tmp", "#recycle"],
                          updateInterval: 5,
                          opacity: "0.9",
                      classes: 'lundiaprem',
                          repositoryConfig: {
                              path: "/home/pi/MagicMirror/modules/Images/lundiaprem/",
                              recursive: true,
                          updateInterval: 5,
                          opacity: "0.9",
          Do you see where is my problem, please?
            sdetweil @anagallis
            @anagallis the MMM-RandomPhoto module doesn’t support multiple instances
            the html ID and Classes are hard coded
              sdetweil @anagallis
              @anagallis delete the MMM-RandomPhoto folder
              cd modules
              rm -rf MMM-RandomPhoto
              and git clone my repo
              cd modules
              git clone https://github.com/sdetweil/MMM-RandomPhoto
              this supports multiple instances
              restart MagicMirror
                anagallis @sdetweil
                @sdetweil aaaah ok, it’s not multiple instances! I understand the problem now.
                The second version you give of the Random-Photo module can’t display local images, it’s only for images via the net. But thank you.
                l have to find a new image module, witch can be multiple instances and with picture in local directories.
                  sdetweil @anagallis
                  @anagallis ah, I see. I found the original. Not the other fork. Same problem
                  Working on it
                    sdetweil @anagallis
                    @anagallis I have redone my fork of the MMM-RandomPhoto module using the correct source, to support multiple instances.
                    to test this do
                    cd ~/MagicMirror/modules
                    git clone https://github.com/sdetweil/MMM-RandomPhoto.git
                    cd MMM-RandomPhoto
                    git checkout multi-instance
                    npm install
                    see the readme for the doc on how to use the new id property to create multiple instances and what you MUST do for css to support each instance… easy, but required.
                      anagallis @sdetweil
                      Waowww! You did a fork for us, marvelous!
                      I’ll test it, and i’ll say you later if if works here.
                        anagallis @anagallis
                        It’s great!
                        But I have a problem with the css.
                        css is applied only if I set the id=“_”, and if I have only one id with this value.
                        When I replace
                        id='L2_'
                        by
                        id='_'
                        See bellow if I done a mistake.
                        here is my custom.css:
                        #L1_randomPhoto, #L2_randomPhoto, #Ma1_randomPhoto, #Ma2_randomPhoto, #Me1_randomPhoto, #Me2_randomPhoto, #J1_randomPhoto, #J2_randomPhoto, #V1_randomPhoto, #V2_randomPhoto img {
                            opacity: 0;
                            position: absolute;
                            top: 0;
                            left: 0;
                            height: 100%;
                            width: 100%;
                            object-fit: cover;
                        #L1_randomPhoto, #L2_randomPhoto, #Ma1_randomPhoto, #Ma2_randomPhoto, #Me1_randomPhoto, #Me2_randomPhoto, #J1_randomPhoto, #J2_randomPhoto, #V1_randomPhoto, #V2_randomPhoto img.grayscale {
                            filter: grayscale(100%);
                        ....etc
                        and a part of the config.json :
                                        //global_schedule: {from: '0 9 * * *', to: '0 13 * * *', groupClass: 'lundimatin'},
                                        //global_schedule: {from: '0 9 * * *', to: '0 17 * * *', groupClass: 'lundiaprem'},
                                	classes: 'scheduler',
                        				module_schedule: {from: '0 9 * * 1', to: '0 13 * * 1' },
                                        repositoryConfig: {
                                            recursive: true,
                                        updateInterval: 5,
                                        opacity: "1",
                        				module_schedule: {from: '0 13 * * 1', to: '0 17 * * 1' },
                                        repositoryConfig: {
                                            recursive: true,
                                        updateInterval: 5,
                                        opacity: "1",
                          sdetweil @anagallis
                          @anagallis said:
                          note you missed one _ (my fault in instructions) there is a root {} section that contains one too
                          :root {
                              --_randomPhoto-blur-value: 0px;
                          if you are going to use comma, then you need to replicate the actual tag too (I think)
                          #L1_randomPhoto img, #L2_randomPhoto img, #Ma1_randomPhoto img, #Ma2_randomPhoto img ,........
                          note the id can be anything, you were using a string for the global schedule classname, you could use the same string
                          here is what I did and verified it worked (without using commas)
                          config
                                          opacity: 0.3,
                                          animationSpeed: 500,
                                          updateInterval: 60,
                                          imageRepository:'localdirectory',
                                          repositoryConfig :{
                                                  path: '/Users/sam/Pictures'
                                          opacity: 0.3,
                                          updateInterval: 60,
                                          repositoryConfig :{
                                                  path: '/Users/sam/Pics'
                          custom.css
                          :root {
                              --foorandomPhoto-blur-value: 0px;
                          #foorandomPhoto img {
                              opacity: 0;
                              position: absolute;;
                              top: 0;
                              left: 0;
                              height: 100%;
                              width: 100%;
                              object-fit: cover;
                          #fooArandomPhoto img.grayscale {
                          #foorandomPhoto img.blur {
                              filter: blur(var(--randomphoto-blur-value));
                          #foorandomPhotoIcon {
                              position: absolute;
                          #foorandomPhotoIcon.rpitop {
                              top: 5px;
                          #foorandomPhotoIcon.rpibottom {
                              bottom: 5px;
                          #foorandomPhotoIcon.rpiright {
                              right: 10px;
                          #foorandomPhotoIcon.rpileft {
                              left: 10px;
                          #foorandomPhotoIcon i {
                              opacity: 1;
                          #foorandomPhotoIcon i.rpihidden {
                              opacity: 0;
                          :root {
                              --_=fribblerandomPhoto-blur-value: 0px;
                          #fribblerandomPhoto img {
                              opacity: 0;
                              top: 0;
                              left: 0;
                              height: 100%;
                              width: 100%;
                              object-fit: cover;
                          #fribblerandomPhoto img.grayscale {
                          #fribblerandomPhoto img.blur {
                          #fribblerandomPhotoIcon {
                              position: absolute;
                          #fribblerandomPhotoIcon.rpitop {
                              top: 5px;
                          #fribblerandomPhotoIcon.rpibottom {
                              bottom: 5px;
                          #fribblerandomPhotoIcon.rpiright {
                              right: 10px;
                          #fribblerandomPhotoIcon.rpileft {
                              left: 10px;
                          #fribblerandomPhotoIcon i {
                              opacity: 1;
                          #fribblerandomPhotoIcon i.rpihidden {
                              opacity: 0;
                          I updated the module README.md to document the change needed there too
                            anagallis @sdetweil
                            I found my mistake!
                            I have copy the custom.css in the path /home/pi/MagicMirror/css and it works great!
                            You’ve just helped me make the schedule accessible to a group of people with disabilities who can’t read. I’m going to show them their half-day schedule using pictures.
                            It’s great that you took the time to help us—thanks again!
                              sdetweil @anagallis
                              @anagallis yes, custom.css is in the MagicMirror/css folder
                              next release (April 1 it will move to the config folder (user files will all be in one place)
