    OpenWeather loaded but info is empty since update
    26 Posts 3 Posters 8.0k Views 3 Watching
      SdR @sdetweil
      made the change and restarted MM but same result, is there a log can can show you after the restart?
        sdetweil @SdR
        @SdR ok,
        do this, stop of there is an error with one command
        pm2 stop all
        cd ~/MagicMirror
        rm -rf node_modules
        rm package-lock.json
        npm run install-mm
        npm run start:x11
          SdR @sdetweil
          @sdetweil ok, did all the commands, no error shown but with the same result again (not showing any weather and weather forecasting).
            sdetweil @SdR
            @SdR Ok, in 2.35 we rewrote the data collection portion of the weather module
            it does NOT support the old version 2.5 openweather api anymore.
            so, to use the openweather provider, you must get a new 3.0 apikey from openweather which requires a credit card, and you get (today) 1000 free api calls. (so net free)
            from a year ago, in the troubleshooting section
            https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
              SdR @sdetweil
              @sdetweil I can confirm that version 2.5 is now definitely not supported anymore.
              I changed it to openmeteo after the changed you suggested and now it works.
              Thank you… your’e a wizard :)
                sdetweil @SdR
                @SdR awesome. Sorry it took so long. Got sidetracked by the MagicMirror install problem, which wasn’t the cause
