    OpenWeather loaded but info is empty since update
    26 Posts 3 Posters 8.2k Views 3 Watching
      SdR @KristjanESPERANTO
      @KristjanESPERANTO I have used the following command guide to update the MM :
      bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
      So i’m not sure if node --run install-mm is still required then.
      im not a expert so i did a little chatgpt search how to pull this info and this is what i got:
      System Information
      manufacturer: ‘Raspberry Pi Foundation’,
      model: ‘Raspberry Pi 4 Model B Rev 1.1’,
      version: ‘b03111’,
      serial: ‘10000000f0815816’,
      uuid: ‘’,
      sku: ‘-’,
      virtual: false,
      raspberry: {
      manufacturer: ‘Sony UK’,
      processor: ‘BCM2711’,
      type: ‘4B’,
      revision: ‘1.1’
      CPU
      brand: ‘BCM2711’,
      vendor: ‘ARM’,
      family: ‘Cortex-A72’,
      model: ‘3’,
      stepping: ‘r0p3’,
      revision: ‘b03111’,
      voltage: ‘’,
      speed: 1.5,
      speedMin: 0.6,
      speedMax: 1.5,
      governor: ‘ondemand’,
      cores: 4,
      physicalCores: 4,
      performanceCores: 4,
      efficiencyCores: 0,
      processors: 1,
      socket: ‘SOC’,
      flags: ‘fp asimd evtstrm crc32 cpuid’,
      virtualization: false,
      cache: { l1d: 131072, l1i: 196608, l2: 1048576, l3: ‘’ }
      Memory
      total: 1935228928,
      free: 96256000,
      used: 1838972928,
      active: 828510208,
      available: 1106718720,
      buffers: 59150336,
      cached: 833519616,
      slab: 339734528,
      buffcache: 1232404480,
      reclaimable: 298536960,
      swaptotal: 1934618624,
      swapused: 10747904,
      swapfree: 1923870720,
      writeback: 0,
      dirty: 0
      @sdetweil regarding git status i have the following info:
      simon@SimPi:~/MagicMirror $ git status
      On branch master
      Your branch is up to date with ‘origin/master’.
      (use “git add …” to update what will be committed)
      (use “git restore …” to discard changes in working directory)
      modified: package-lock.json
      modified: package.json
      Untracked files:
      (use “git add …” to include in what will be committed)
      core.2761
      core.4822
      installers/
      run-start.sh
      splashscreen/
      no changes added to commit (use “git add” and/or “git commit -a”)
        sdetweil @SdR
        @SdR ok. The upgrade script is mine
        We meant the system-info section of the MagicMirror startup messages.
        Runstart.sh is mine for when electron is not found
        Can you
        git diff package.json
        And
        ls node_modules/electron
          SdR @sdetweil
          @sdetweil tnx for the commands, this helps :)
          i have:
          diff --git a/package.json b/package.json
          index 5cad85d…c0ae855 100644
          — a/package.json
          +++ b/package.json
          @@ -87,6 +87,7 @@
          “*.css”: “stylelint --fix”
          “dependencies”: {
          •           "@electron/rebuild": "^4.0.3",
                      "@fontsource/roboto": "^5.2.10",
                      "@fontsource/roboto-condensed": "^5.2.8",
                      "@fortawesome/fontawesome-free": "^7.2.0",
          and
          simon@SimPi:~/MagicMirror $ ls node_modules/electron
          abi_version checksums.json cli.js dist electron.d.ts index.js install.js LICENSE package.json path.txt README.md
            sdetweil @SdR
            @SdR ok. Looks like something added electron/rebuild
            And fonts
              SdR @sdetweil
              @sdetweil Ok, as mentioned I only did the update command as mentioned earlier.
              Is there something I need to do now to make it work again?
                sdetweil @SdR
                @SdR can you show me the end, last 20 lines of the MagicMirror/installers/upgrade.log
                  SdR @sdetweil
                  @sdetweil appreciate the help!
                  Here they are:
                  magicmirror@2.35.0 postinstall
                  git clean -df fonts vendor modules/default
                  magicmirror@2.35.0 prepare
                  [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                  no husky installed.
                  added 379 packages in 1m
                  82 packages are looking for funding
                  run npm fund for details
                  npm notice
                  npm notice New major version of npm available! 10.9.4 -> 11.12.1
                  npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.12.1
                  npm notice To update run: npm install -g npm@11.12.1
                  npm notice
                  npm install completed - Sun Apr 5 10:07:56 CEST 2026 on base
                  added 594 packages in 30s
                  260 packages are looking for funding
                  fixing sandbox permissions
                  downloading dumpactivemodules script
                  no modules found needing npm refresh
                  restoring custom.css
                  removing git alias
                  we stashed a set of files that appear changed from the latest repo versions. you should review them
                  Upgrade ended - Sun Apr 5 10:08:29 CEST 2026
                    sdetweil @SdR
                    @SdR >Sun Apr 5 10:08:29 CEST 2026
                    there was a bug in the upgrade I fixed at 21:00 US Central time
                    can you edit ~/MagicMirror/installers/mm.sh
                    and change the
                    npm start
                    to
                    npm run start:x11
                    then you can
                    pm2 restart MagicMirror
                      SdR @sdetweil
                      I have 2 in there after “DISPLAY”… do I need to change both?
                      #!/bin/bash
                      cd /home/simon/MagicMirror
                      if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                      if WAYLAND_DISPLAYis set, use it, else set to -0
                      export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                      npm run start:wayland
                      else
                      DISPLAY=:0 npm start
                      fi
                      #DISPLAY=:0 npm start
                        sdetweil @SdR
                        @SdR said:
                        DISPLAY=:0 npm start <----- change this one
                        fi
                        #DISPLAY=:0 npm start <— this one is commented out (#)
                          SdR @sdetweil
                          made the change and restarted MM but same result, is there a log can can show you after the restart?
                            sdetweil @SdR
                            @SdR ok,
                            do this, stop of there is an error with one command
                            pm2 stop all
                            rm -rf node_modules
                            rm package-lock.json
                            npm run install-mm
                            npm run start:x11
                              SdR @sdetweil
                              @sdetweil ok, did all the commands, no error shown but with the same result again (not showing any weather and weather forecasting).
                                sdetweil @SdR
                                @SdR Ok, in 2.35 we rewrote the data collection portion of the weather module
                                it does NOT support the old version 2.5 openweather api anymore.
                                so, to use the openweather provider, you must get a new 3.0 apikey from openweather which requires a credit card, and you get (today) 1000 free api calls. (so net free)
                                from a year ago, in the troubleshooting section
                                https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
                                  SdR @sdetweil
                                  @sdetweil I can confirm that version 2.5 is now definitely not supported anymore.
                                  I changed it to openmeteo after the changed you suggested and now it works.
                                  Thank you… your’e a wizard :)
                                    sdetweil @SdR
                                    @SdR awesome. Sorry it took so long. Got sidetracked by the MagicMirror install problem, which wasn’t the cause
