    OpenWeather loaded but info is empty since update
    26 Posts 3 Posters 7.7k Views 3 Watching
    • KristjanESPERANTOK Offline
      KristjanESPERANTO Module Developer @SdR
      @SdR I tested this config on my side and it works. I only had to add one missing closing bracket in your snippet.
      Do you see any errors in the terminal?
      Also, after pulling the new version, did you run: node --run install-mm?
      If openmeteo is also empty, this looks like a general config/runtime issue, not only an OpenWeather API issue.
      Please show us the systeminformation from the terminal. Looks like this:
      [2026-04-07 21:13:27.184] [INFO]  [systeminformation]
      ####  System Information  ####
      - SYSTEM:   manufacturer: Micro-Star International Co., Ltd.; model: MS-7D75; virtual: false; MM: v2.36.0-develop
      - OS:       platform: linux; distro: Debian GNU/Linux; release: forky/sid; arch: x64; kernel: 6.19.10+deb14-amd64
      - VERSIONS: electron: 41.1.1; used node: 25.9.0; installed node: 25.9.0; npm: 11.12.1; pm2: 6.0.14
      - ENV:      XDG_SESSION_TYPE: wayland; MM_CONFIG_FILE: undefined
                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
      - RAM:      total: 61881.24 MB; free: 42885.43 MB; used: 18995.81 MB
      - OTHERS:   uptime: 45 minutes; timeZone: Europe/Berlin
      S S 2 Replies Last reply Reply Quote 0
        sdetweil @KristjanESPERANTO
        @KristjanESPERANTO and a git status
          SdR @KristjanESPERANTO
          @KristjanESPERANTO I have used the following command guide to update the MM :
          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
          So i’m not sure if node --run install-mm is still required then.
          im not a expert so i did a little chatgpt search how to pull this info and this is what i got:
          System Information
          manufacturer: ‘Raspberry Pi Foundation’,
          model: ‘Raspberry Pi 4 Model B Rev 1.1’,
          version: ‘b03111’,
          serial: ‘10000000f0815816’,
          uuid: ‘’,
          sku: ‘-’,
          virtual: false,
          raspberry: {
          manufacturer: ‘Sony UK’,
          processor: ‘BCM2711’,
          type: ‘4B’,
          revision: ‘1.1’
          CPU
          brand: ‘BCM2711’,
          vendor: ‘ARM’,
          family: ‘Cortex-A72’,
          model: ‘3’,
          stepping: ‘r0p3’,
          revision: ‘b03111’,
          voltage: ‘’,
          speed: 1.5,
          speedMin: 0.6,
          speedMax: 1.5,
          governor: ‘ondemand’,
          cores: 4,
          physicalCores: 4,
          performanceCores: 4,
          efficiencyCores: 0,
          processors: 1,
          socket: ‘SOC’,
          flags: ‘fp asimd evtstrm crc32 cpuid’,
          virtualization: false,
          cache: { l1d: 131072, l1i: 196608, l2: 1048576, l3: ‘’ }
          Memory
          total: 1935228928,
          free: 96256000,
          used: 1838972928,
          active: 828510208,
          available: 1106718720,
          buffers: 59150336,
          cached: 833519616,
          slab: 339734528,
          buffcache: 1232404480,
          reclaimable: 298536960,
          swaptotal: 1934618624,
          swapused: 10747904,
          swapfree: 1923870720,
          writeback: 0,
          dirty: 0
          @sdetweil regarding git status i have the following info:
          simon@SimPi:~/MagicMirror $ git status
          On branch master
          Your branch is up to date with ‘origin/master’.
          (use “git add …” to update what will be committed)
          (use “git restore …” to discard changes in working directory)
          modified: package-lock.json
          modified: package.json
          Untracked files:
          (use “git add …” to include in what will be committed)
          core.2761
          core.4822
          installers/
          run-start.sh
          splashscreen/
          no changes added to commit (use “git add” and/or “git commit -a”)
            sdetweil @SdR
            @SdR ok. The upgrade script is mine
            We meant the system-info section of the MagicMirror startup messages.
            Runstart.sh is mine for when electron is not found
            Can you
            git diff package.json
            And
            ls node_modules/electron
              SdR @sdetweil
              @sdetweil tnx for the commands, this helps :)
              i have:
              diff --git a/package.json b/package.json
              index 5cad85d…c0ae855 100644
              — a/package.json
              +++ b/package.json
              @@ -87,6 +87,7 @@
              “*.css”: “stylelint --fix”
              “dependencies”: {
              •           "@electron/rebuild": "^4.0.3",
                          "@fontsource/roboto": "^5.2.10",
                          "@fontsource/roboto-condensed": "^5.2.8",
                          "@fortawesome/fontawesome-free": "^7.2.0",
              and
              simon@SimPi:~/MagicMirror $ ls node_modules/electron
              abi_version checksums.json cli.js dist electron.d.ts index.js install.js LICENSE package.json path.txt README.md
                sdetweil @SdR
                @SdR ok. Looks like something added electron/rebuild
                And fonts
                  SdR @sdetweil
                  @sdetweil Ok, as mentioned I only did the update command as mentioned earlier.
                  Is there something I need to do now to make it work again?
                    sdetweil @SdR
                    @SdR can you show me the end, last 20 lines of the MagicMirror/installers/upgrade.log
                      SdR @sdetweil
                      @sdetweil appreciate the help!
                      Here they are:
                      magicmirror@2.35.0 postinstall
                      git clean -df fonts vendor modules/default
                      magicmirror@2.35.0 prepare
                      [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                      no husky installed.
                      added 379 packages in 1m
                      82 packages are looking for funding
                      run npm fund for details
                      npm notice
                      npm notice New major version of npm available! 10.9.4 -> 11.12.1
                      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.12.1
                      npm notice To update run: npm install -g npm@11.12.1
                      npm notice
                      npm install completed - Sun Apr 5 10:07:56 CEST 2026 on base
                      added 594 packages in 30s
                      260 packages are looking for funding
                      fixing sandbox permissions
                      downloading dumpactivemodules script
                      no modules found needing npm refresh
                      restoring custom.css
                      removing git alias
                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                      Upgrade ended - Sun Apr 5 10:08:29 CEST 2026
                        sdetweil @SdR
                        @SdR >Sun Apr 5 10:08:29 CEST 2026
                        there was a bug in the upgrade I fixed at 21:00 US Central time
                        can you edit ~/MagicMirror/installers/mm.sh
                        and change the
                        npm start
                        to
                        npm run start:x11
                        then you can
                        pm2 restart MagicMirror
                          SdR @sdetweil
                          I have 2 in there after “DISPLAY”… do I need to change both?
                          #!/bin/bash
                          cd /home/simon/MagicMirror
                          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                          if WAYLAND_DISPLAYis set, use it, else set to -0
                          export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                          npm run start:wayland
                          else
                          DISPLAY=:0 npm start
                          fi
                          #DISPLAY=:0 npm start
                            sdetweil @SdR
                            @SdR said:
                            DISPLAY=:0 npm start <----- change this one
                            fi
                            #DISPLAY=:0 npm start <— this one is commented out (#)
                              SdR @sdetweil
                              made the change and restarted MM but same result, is there a log can can show you after the restart?
                                sdetweil @SdR
                                @SdR ok,
                                do this, stop of there is an error with one command
                                pm2 stop all
                                rm -rf node_modules
                                rm package-lock.json
                                npm run install-mm
                                npm run start:x11
                                  SdR @sdetweil
                                  @sdetweil ok, did all the commands, no error shown but with the same result again (not showing any weather and weather forecasting).
                                    sdetweil @SdR
                                    @SdR Ok, in 2.35 we rewrote the data collection portion of the weather module
                                    it does NOT support the old version 2.5 openweather api anymore.
                                    so, to use the openweather provider, you must get a new 3.0 apikey from openweather which requires a credit card, and you get (today) 1000 free api calls. (so net free)
                                    from a year ago, in the troubleshooting section
                                    https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
                                      SdR @sdetweil
                                      @sdetweil I can confirm that version 2.5 is now definitely not supported anymore.
                                      I changed it to openmeteo after the changed you suggested and now it works.
                                      Thank you… your’e a wizard :)
                                        sdetweil @SdR
                                        @SdR awesome. Sorry it took so long. Got sidetracked by the MagicMirror install problem, which wasn’t the cause
