    OpenWeather loaded but info is empty since update
    26 Posts 3 Posters 1.3k Views 3 Watching
      SdR
      I just updated to the latest version of MM but since the update my OpenWeather info is not working anymore, the info is all empty which was working fine before the update. weather.jpg
      This is my config.js , does anyone have a solution?
      		module: "weather",
      			weatherEndpoint:"/weather",
      			type: "current",
      			locationID: "2750064", //ID from http://bulk.openweathermap.org/sample/city.list.json.gz; unzip the gz file and find your city
      			apiVersion: "2.5",
      			apiKey: "xxxxxxxxxx"
      		module: "weather",
      		header: "Weather Forecast",
      			weatherEndpoint:"/forecast",
      			type: "forecast",
      			colored: "true",
      			apiVersion: "2.5",
      			apiKey: "xxxxxxx"
      S KristjanESPERANTOK 3 Replies Last reply Reply Quote 0
        sdetweil @SdR
        @SdR in the car, see the troubleshooting
        • KristjanESPERANTOK Online
          KristjanESPERANTO Module Developer @SdR
          @SdR, did apiVersion: "2.5" really still work before the MM update? That version was deprecated a long time ago (June 2024). See https://forum.magicmirror.builders/topic/18662/modules-using-openweather-api-need-review.
          KristjanESPERANTOK S 2 Replies Last reply Reply Quote 0
            KristjanESPERANTO Module Developer @KristjanESPERANTO
            So that you can start receiving weather data again right away and don’t have to wait until we’ve figured the issue out, I’d suggest you try a different provider.
            https://docs.magicmirror.builders/modules/weather.html
              sdetweil @SdR
              @SdR see https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
              from the troubleshooting section
                SdR @KristjanESPERANTO
                Yes, with the settings I posted it still worked like a charm… until the MM recent update.
                  SdR @sdetweil
                  I checked this section, but couldn’t relate it to my situation. This basicly states to change to API 3.0 or change the provider.
                  I try to change the provider like advised by @kristjanesperanto but I really like the openweather, so I hope he is able to find and solve the issues based on the info I posted.
                    SdR
                    @kristjanesperanto I have changed it, as test, with the following copy/paste of a different topic, but got the exact same result… module is showing empty and not loading any weather info:
                    		module: "weather",
                    			weatherProvider: "openmeteo",
                    			type: "current",
                    			lat: 40.776676,
                    			lon: -73.971321
                    		module: "weather",
                    			type: "forecast",
                    			lat: 40.776676,
                    			lon: -73.971321
                      @SdR I tested this config on my side and it works. I only had to add one missing closing bracket in your snippet.
                      Do you see any errors in the terminal?
                      Also, after pulling the new version, did you run: node --run install-mm?
                      If openmeteo is also empty, this looks like a general config/runtime issue, not only an OpenWeather API issue.
                      Please show us the systeminformation from the terminal. Looks like this:
                      [2026-04-07 21:13:27.184] [INFO]  [systeminformation]
                      ####  System Information  ####
                      - SYSTEM:   manufacturer: Micro-Star International Co., Ltd.; model: MS-7D75; virtual: false; MM: v2.36.0-develop
                      - OS:       platform: linux; distro: Debian GNU/Linux; release: forky/sid; arch: x64; kernel: 6.19.10+deb14-amd64
                      - VERSIONS: electron: 41.1.1; used node: 25.9.0; installed node: 25.9.0; npm: 11.12.1; pm2: 6.0.14
                      - ENV:      XDG_SESSION_TYPE: wayland; MM_CONFIG_FILE: undefined
                                  WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
                      - RAM:      total: 61881.24 MB; free: 42885.43 MB; used: 18995.81 MB
                      - OTHERS:   uptime: 45 minutes; timeZone: Europe/Berlin
                      S S 2 Replies Last reply Reply Quote 0
                        sdetweil @KristjanESPERANTO
                        @KristjanESPERANTO and a git status
                          @KristjanESPERANTO I have used the following command guide to update the MM :
                          bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                          So i’m not sure if node --run install-mm is still required then.
                          im not a expert so i did a little chatgpt search how to pull this info and this is what i got:
                          System Information
                          manufacturer: ‘Raspberry Pi Foundation’,
                          model: ‘Raspberry Pi 4 Model B Rev 1.1’,
                          version: ‘b03111’,
                          serial: ‘10000000f0815816’,
                          uuid: ‘’,
                          sku: ‘-’,
                          virtual: false,
                          raspberry: {
                          manufacturer: ‘Sony UK’,
                          processor: ‘BCM2711’,
                          type: ‘4B’,
                          revision: ‘1.1’
                          CPU
                          brand: ‘BCM2711’,
                          vendor: ‘ARM’,
                          family: ‘Cortex-A72’,
                          model: ‘3’,
                          stepping: ‘r0p3’,
                          revision: ‘b03111’,
                          voltage: ‘’,
                          speed: 1.5,
                          speedMin: 0.6,
                          speedMax: 1.5,
                          governor: ‘ondemand’,
                          cores: 4,
                          physicalCores: 4,
                          performanceCores: 4,
                          efficiencyCores: 0,
                          processors: 1,
                          socket: ‘SOC’,
                          flags: ‘fp asimd evtstrm crc32 cpuid’,
                          virtualization: false,
                          cache: { l1d: 131072, l1i: 196608, l2: 1048576, l3: ‘’ }
                          Memory
                          total: 1935228928,
                          free: 96256000,
                          used: 1838972928,
                          active: 828510208,
                          available: 1106718720,
                          buffers: 59150336,
                          cached: 833519616,
                          slab: 339734528,
                          buffcache: 1232404480,
                          reclaimable: 298536960,
                          swaptotal: 1934618624,
                          swapused: 10747904,
                          swapfree: 1923870720,
                          writeback: 0,
                          dirty: 0
                          @sdetweil regarding git status i have the following info:
                          simon@SimPi:~/MagicMirror $ git status
                          On branch master
                          Your branch is up to date with ‘origin/master’.
                          (use “git add …” to update what will be committed)
                          (use “git restore …” to discard changes in working directory)
                          modified: package-lock.json
                          modified: package.json
                          Untracked files:
                          (use “git add …” to include in what will be committed)
                          core.2761
                          core.4822
                          installers/
                          run-start.sh
                          splashscreen/
                          no changes added to commit (use “git add” and/or “git commit -a”)
                            sdetweil @SdR
                            @SdR ok. The upgrade script is mine
                            We meant the system-info section of the MagicMirror startup messages.
                            Runstart.sh is mine for when electron is not found
                            Can you
                            git diff package.json
                            And
                            ls node_modules/electron
                              SdR @sdetweil
                              @sdetweil tnx for the commands, this helps :)
                              i have:
                              diff --git a/package.json b/package.json
                              index 5cad85d…c0ae855 100644
                              — a/package.json
                              +++ b/package.json
                              @@ -87,6 +87,7 @@
                              “*.css”: “stylelint --fix”
                              “dependencies”: {
                              •           "@electron/rebuild": "^4.0.3",
                                          "@fontsource/roboto": "^5.2.10",
                                          "@fontsource/roboto-condensed": "^5.2.8",
                                          "@fortawesome/fontawesome-free": "^7.2.0",
                              and
                              simon@SimPi:~/MagicMirror $ ls node_modules/electron
                              abi_version checksums.json cli.js dist electron.d.ts index.js install.js LICENSE package.json path.txt README.md
                                sdetweil @SdR
                                @SdR ok. Looks like something added electron/rebuild
                                And fonts
                                  SdR @sdetweil
                                  @sdetweil Ok, as mentioned I only did the update command as mentioned earlier.
                                  Is there something I need to do now to make it work again?
                                    sdetweil @SdR
                                    @SdR can you show me the end, last 20 lines of the MagicMirror/installers/upgrade.log
                                      SdR @sdetweil
                                      @sdetweil appreciate the help!
                                      Here they are:
                                      magicmirror@2.35.0 postinstall
                                      git clean -df fonts vendor modules/default
                                      magicmirror@2.35.0 prepare
                                      [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                                      no husky installed.
                                      added 379 packages in 1m
                                      82 packages are looking for funding
                                      run npm fund for details
                                      npm notice
                                      npm notice New major version of npm available! 10.9.4 -> 11.12.1
                                      npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.12.1
                                      npm notice To update run: npm install -g npm@11.12.1
                                      npm notice
                                      npm install completed - Sun Apr 5 10:07:56 CEST 2026 on base
                                      added 594 packages in 30s
                                      260 packages are looking for funding
                                      fixing sandbox permissions
                                      downloading dumpactivemodules script
                                      no modules found needing npm refresh
                                      restoring custom.css
                                      removing git alias
                                      we stashed a set of files that appear changed from the latest repo versions. you should review them
                                      Upgrade ended - Sun Apr 5 10:08:29 CEST 2026
                                        sdetweil @SdR
                                        @SdR >Sun Apr 5 10:08:29 CEST 2026
                                        there was a bug in the upgrade I fixed at 21:00 US Central time
                                        can you edit ~/MagicMirror/installers/mm.sh
                                        and change the
                                        npm start
                                        to
                                        npm run start:x11
                                        then you can
                                        pm2 restart MagicMirror
                                          SdR @sdetweil
                                          I have 2 in there after “DISPLAY”… do I need to change both?
                                          #!/bin/bash
                                          cd /home/simon/MagicMirror
                                          if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                          if WAYLAND_DISPLAYis set, use it, else set to -0
                                          export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                          npm run start:wayland
                                          else
                                          DISPLAY=:0 npm start
                                          fi
                                          #DISPLAY=:0 npm start
                                            sdetweil @SdR
                                            @SdR said:
                                            DISPLAY=:0 npm start <----- change this one
                                            fi
                                            #DISPLAY=:0 npm start <— this one is commented out (#)
