    OpenWeather loaded but info is empty since update
    26 Posts 3 Posters 8.2k Views 3 Watching
      SdR @KristjanESPERANTO
      @KristjanESPERANTO said:
      @SdR, did apiVersion: "2.5" really still work before the MM update? That version was deprecated a long time ago (June 2024). See https://forum.magicmirror.builders/topic/18662/modules-using-openweather-api-need-review.
      Yes, with the settings I posted it still worked like a charm… until the MM recent update.
        SdR @sdetweil
        @sdetweil said:
        @SdR see https://forum.magicmirror.builders/topic/19323/version-2.30.0-weather-module-stuck-loading-worked-fine-before-upgrade?page=1
        from the troubleshooting section
        I checked this section, but couldn’t relate it to my situation. This basicly states to change to API 3.0 or change the provider.
        I try to change the provider like advised by @kristjanesperanto but I really like the openweather, so I hope he is able to find and solve the issues based on the info I posted.
          SdR
          @kristjanesperanto I have changed it, as test, with the following copy/paste of a different topic, but got the exact same result… module is showing empty and not loading any weather info:
          		module: "weather",
          			weatherProvider: "openmeteo",
          			type: "current",
          			lat: 40.776676,
          			lon: -73.971321
          		module: "weather",
          		header: "Weather Forecast",
          			type: "forecast",
          			lat: 40.776676,
          			lon: -73.971321
          KristjanESPERANTOK 1 Reply Last reply
          • KristjanESPERANTOK
            KristjanESPERANTO Module Developer @SdR
            @SdR I tested this config on my side and it works. I only had to add one missing closing bracket in your snippet.
            Do you see any errors in the terminal?
            Also, after pulling the new version, did you run: node --run install-mm?
            If openmeteo is also empty, this looks like a general config/runtime issue, not only an OpenWeather API issue.
            Please show us the systeminformation from the terminal. Looks like this:
            [2026-04-07 21:13:27.184] [INFO]  [systeminformation]
            ####  System Information  ####
            - SYSTEM:   manufacturer: Micro-Star International Co., Ltd.; model: MS-7D75; virtual: false; MM: v2.36.0-develop
            - OS:       platform: linux; distro: Debian GNU/Linux; release: forky/sid; arch: x64; kernel: 6.19.10+deb14-amd64
            - VERSIONS: electron: 41.1.1; used node: 25.9.0; installed node: 25.9.0; npm: 11.12.1; pm2: 6.0.14
            - ENV:      XDG_SESSION_TYPE: wayland; MM_CONFIG_FILE: undefined
                        WAYLAND_DISPLAY:  wayland-0; DISPLAY: :0; ELECTRON_ENABLE_GPU: undefined
            - RAM:      total: 61881.24 MB; free: 42885.43 MB; used: 18995.81 MB
            - OTHERS:   uptime: 45 minutes; timeZone: Europe/Berlin
            S S 2 Replies Last reply
              sdetweil @KristjanESPERANTO
              @KristjanESPERANTO and a git status
                @KristjanESPERANTO I have used the following command guide to update the MM :
                bash -c “$(curl -sL https://raw.githubusercontent.com/sdetweil/MagicMirror_scripts/master/upgrade-script.sh)” apply
                So i’m not sure if node --run install-mm is still required then.
                im not a expert so i did a little chatgpt search how to pull this info and this is what i got:
                System Information
                manufacturer: ‘Raspberry Pi Foundation’,
                model: ‘Raspberry Pi 4 Model B Rev 1.1’,
                version: ‘b03111’,
                serial: ‘10000000f0815816’,
                uuid: ‘’,
                sku: ‘-’,
                virtual: false,
                raspberry: {
                manufacturer: ‘Sony UK’,
                processor: ‘BCM2711’,
                type: ‘4B’,
                revision: ‘1.1’
                CPU
                brand: ‘BCM2711’,
                vendor: ‘ARM’,
                family: ‘Cortex-A72’,
                model: ‘3’,
                stepping: ‘r0p3’,
                revision: ‘b03111’,
                voltage: ‘’,
                speed: 1.5,
                speedMin: 0.6,
                speedMax: 1.5,
                governor: ‘ondemand’,
                cores: 4,
                physicalCores: 4,
                performanceCores: 4,
                efficiencyCores: 0,
                processors: 1,
                socket: ‘SOC’,
                flags: ‘fp asimd evtstrm crc32 cpuid’,
                virtualization: false,
                cache: { l1d: 131072, l1i: 196608, l2: 1048576, l3: ‘’ }
                Memory
                total: 1935228928,
                free: 96256000,
                used: 1838972928,
                active: 828510208,
                available: 1106718720,
                buffers: 59150336,
                cached: 833519616,
                slab: 339734528,
                buffcache: 1232404480,
                reclaimable: 298536960,
                swaptotal: 1934618624,
                swapused: 10747904,
                swapfree: 1923870720,
                writeback: 0,
                dirty: 0
                @sdetweil regarding git status i have the following info:
                simon@SimPi:~/MagicMirror $ git status
                On branch master
                Your branch is up to date with ‘origin/master’.
                (use “git add …” to update what will be committed)
                (use “git restore …” to discard changes in working directory)
                modified: package-lock.json
                modified: package.json
                Untracked files:
                (use “git add …” to include in what will be committed)
                core.2761
                core.4822
                installers/
                run-start.sh
                splashscreen/
                no changes added to commit (use “git add” and/or “git commit -a”)
                  sdetweil @SdR
                  @SdR ok. The upgrade script is mine
                  We meant the system-info section of the MagicMirror startup messages.
                  Runstart.sh is mine for when electron is not found
                  Can you
                  git diff package.json
                  And
                  ls node_modules/electron
                    SdR @sdetweil
                    @sdetweil tnx for the commands, this helps :)
                    i have:
                    diff --git a/package.json b/package.json
                    index 5cad85d…c0ae855 100644
                    — a/package.json
                    +++ b/package.json
                    @@ -87,6 +87,7 @@
                    “*.css”: “stylelint --fix”
                    “dependencies”: {
                    •           "@electron/rebuild": "^4.0.3",
                                "@fontsource/roboto": "^5.2.10",
                                "@fontsource/roboto-condensed": "^5.2.8",
                                "@fortawesome/fontawesome-free": "^7.2.0",
                    and
                    simon@SimPi:~/MagicMirror $ ls node_modules/electron
                    abi_version checksums.json cli.js dist electron.d.ts index.js install.js LICENSE package.json path.txt README.md
                      sdetweil @SdR
                      @SdR ok. Looks like something added electron/rebuild
                      And fonts
                        SdR @sdetweil
                        @sdetweil Ok, as mentioned I only did the update command as mentioned earlier.
                        Is there something I need to do now to make it work again?
                          sdetweil @SdR
                          @SdR can you show me the end, last 20 lines of the MagicMirror/installers/upgrade.log
                            SdR @sdetweil
                            @sdetweil appreciate the help!
                            Here they are:
                            magicmirror@2.35.0 postinstall
                            git clean -df fonts vendor modules/default
                            magicmirror@2.35.0 prepare
                            [ -f node_modules/.bin/husky ] && husky || echo no husky installed.
                            no husky installed.
                            added 379 packages in 1m
                            82 packages are looking for funding
                            run npm fund for details
                            npm notice
                            npm notice New major version of npm available! 10.9.4 -> 11.12.1
                            npm notice Changelog: https://github.com/npm/cli/releases/tag/v11.12.1
                            npm notice To update run: npm install -g npm@11.12.1
                            npm notice
                            npm install completed - Sun Apr 5 10:07:56 CEST 2026 on base
                            added 594 packages in 30s
                            260 packages are looking for funding
                            fixing sandbox permissions
                            downloading dumpactivemodules script
                            no modules found needing npm refresh
                            restoring custom.css
                            removing git alias
                            we stashed a set of files that appear changed from the latest repo versions. you should review them
                            Upgrade ended - Sun Apr 5 10:08:29 CEST 2026
                              sdetweil @SdR
                              @SdR >Sun Apr 5 10:08:29 CEST 2026
                              there was a bug in the upgrade I fixed at 21:00 US Central time
                              can you edit ~/MagicMirror/installers/mm.sh
                              and change the
                              npm start
                              to
                              npm run start:x11
                              then you can
                              pm2 restart MagicMirror
                                SdR @sdetweil
                                I have 2 in there after “DISPLAY”… do I need to change both?
                                #!/bin/bash
                                cd /home/simon/MagicMirror
                                if [ $(ps -ef | grep -v grep | grep -i -e xway -e labwc | wc -l) -ne 0 ]; then
                                if WAYLAND_DISPLAYis set, use it, else set to -0
                                export WAYLAND_DISPLAY=${WAYLAND_DISPLAY:=wayland-0}
                                npm run start:wayland
                                else
                                DISPLAY=:0 npm start
                                fi
                                #DISPLAY=:0 npm start
                                  sdetweil @SdR
                                  @SdR said:
                                  DISPLAY=:0 npm start <----- change this one
                                  fi
                                  #DISPLAY=:0 npm start <— this one is commented out (#)
                                    SdR @sdetweil
                                    made the change and restarted MM but same result, is there a log can can show you after the restart?
                                      sdetweil @SdR
                                      @SdR ok,
                                      do this, stop of there is an error with one command
                                      pm2 stop all
                                      rm -rf node_modules
                                      rm package-lock.json
                                      npm run install-mm
                                      npm run start:x11
                                        SdR @sdetweil
                                        @sdetweil ok, did all the commands, no error shown but with the same result again (not showing any weather and weather forecasting).
                                          sdetweil @SdR
                                          @SdR Ok, in 2.35 we rewrote the data collection portion of the weather module
                                          it does NOT support the old version 2.5 openweather api anymore.
                                          so, to use the openweather provider, you must get a new 3.0 apikey from openweather which requires a credit card, and you get (today) 1000 free api calls. (so net free)
                                          from a year ago, in the troubleshooting section
                                            SdR @sdetweil
                                            @sdetweil I can confirm that version 2.5 is now definitely not supported anymore.
                                            I changed it to openmeteo after the changed you suggested and now it works.
                                            Thank you… your’e a wizard :)
