    Outlook 365 calendar not loading
    1 Posts 1 Posters 2.2k Views 1 Watching
      spacevolt
      Hi there, so I am not having any luck loading in my Outlook 365 calendar. I’ve tried it with a Google Calendar and that works but not for an the Outlook calendar… it stays stuck at Loading.
      Anyone have any solutions they may have tried?
      I also don’t want to export/import it into gCal since there’s currently problems with both services synching properly.
      pi@raspi:~/MagicMirror $ npm start
      > magicmirror@2.1.0 start /home/pi/MagicMirror
      > electron js/electron.js
      Starting MagicMirror: v2.1.0
      Loading config ...
      Loading module helpers ...
      No helper found for module: MMM-forecast-io.
      All module helpers loaded.
      Starting server op port 8585 ...
      Server started ...
      Starting module: newsfeed
      Launching application.
      Create new calendar fetcher for url: https://outlook.office365.com/owa/calendar/372cc3ce0f234db993ecbc707d461480@criticalmass.com/25812ef3264346e38bcbfaf68369b7c64173571250934396679/calendar.ics - Interval: 300000
      Create new news fetcher for url: http://www.nytimes.com/services/xml/rss/nyt/HomePage.xml - Interval: 300000
      TypeError: curr.start.toISOString is not a function
          at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:39:40)
          at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:257:41)
          at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:298:20)
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:187:22)
          at emitTwo (events.js:106:13)
          at Request.emit (events.js:191:7)
          at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1126:10)
          at emitOne (events.js:96:13)
          at Request.emit (events.js:188:7)
