    MMM-iHaveBeenThere how to adjust zoom
    6 Posts 4 Posters 3.4k Views 4 Watching
    • foxF Offline
      fox
      First, thanks to the creator.
      Has anyone got the zoom level working? I wanted to zoom to USA and Australia.
      • MrCoffeeM Offline
        MrCoffee
        Hey fox,
        although your post was made a year ago … did you get it running?
        I want to see the whole world too and don´t get it.
        Thx
        • N Offline
          ninjabreadman @MrCoffee
          @mrcoffee What does your config look like? Quickly reading the readme, it seems it should be:
            module: 'MMM-iHaveBeenThere',
            position: 'lower_third',
                zoomLevel: 0
          You can also check out the map examples at AMCharts on which it is built.
          The default zoomLevel is 4.5. Have you tried incrrmenting it down (e.g. 4, 3.5, 3, etc) to see if it’s working and does what you want?
          Problem with config or JavaScript? Copy/paste it into JSHint.
          Check out the detailed walkthroughs on install, config, modules, etc.
          MrCoffeeM 1 Reply Last reply Reply Quote 0
          • MrCoffeeM Offline
            MrCoffee @ninjabreadman
            @ninjabreadman
            Thanks for the help.
            I tried it again and found my mistake.
            Like you said, the default is 4.5.
            I testet small adjustment steps and then jumped to 0.
            However 0 is not zero zoom. I am not sure what it is.
            But it seems like I skipped the 1 which is no zoom.
            With zoomLevel 1 it was easy to adjust the zoomLongitude and zoomLatitude.
            Thank you!
            T 1 Reply Last reply Reply Quote 1
            • T Offline
              Thelonegeek @MrCoffee
              @ninjabreadman @MrCoffee
              I seriously have no idea what you guys are talking about since you guys were last seen on the forum i am dropping a text here so please excuse me for that i am a complete noob in python and magic mirror world so please ignore my foolish questions
              my problem is i am trying of follow the tutorial given on the youtube channel by Hacker Shack in which they have built the AI Magic Mirror so i just wanted to make this as my last sem project but when i tried cloning and running the MM2 by michmich i could easily setup and it was runninng with the normal modules present by default but when i tried this tutorial i am not abe to run npm only even sudo npm install npm install && npm insta start noothing is working on my macbook air i cant boot only below is the error which i am getting and i am followin this tutorial for magic mirror.
              [https://www.youtube.com/watch?v=ejnE6DM-hqU](**Please see this video i am doing the same thing but when i use npm start or sudo npm start i get these error eveyrtime onmy macbook air **)
              Please follow this for error i have posted the same in the group but no one has helped still please teach i want to make my project before 18th it really urgent in want to put this on my screen i have Rpi b- macbook air everything please help guys.
              https://forum.magicmirror.builders/topic/7146/cant-run-npm-start-or-npm-install-on-my-macbook-air-please-help/2
              @thelonegeek
              • MrCoffeeM Offline
                MrCoffee @Thelonegeek
                @thelonegeek
                Sorry. I am absolutely no expert in this.
                I dont even have a mac book.
