MagicMirror² v2.20.0 is available! For more information about this release, check out this topic.
Can't Start my Magic Mirror
Here is the error that i get when i try to start the mirror with the folowing comand: npm start
Error here it is!!!
root@SmartMirror:~/MagicMirror/config# npm start > magicmirror@2.1.0 start /root/MagicMirror > electron js/electron.js npm ERR! Linux 4.4.50-v7+ npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start" npm ERR! node v6.10.0 npm ERR! npm v3.10.10 npm ERR! code ELIFECYCLE npm ERR! magicmirror@2.1.0 start: `electron js/electron.js` npm ERR! Exit status 1 npm ERR! npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'. npm ERR! Make sure you have the latest version of node.js and npm installed. npm ERR! If you do, this is most likely a problem with the magicmirror package, npm ERR! not with npm itself. npm ERR! Tell the author that this fails on your system: npm ERR! electron js/electron.js npm ERR! You can get information on how to open an issue for this project with: npm ERR! npm bugs magicmirror npm ERR! Or if that isn't available, you can get their info via: npm ERR! npm owner ls magicmirror npm ERR! There is likely additional logging output above. npm ERR! Please include the following file with any support request: npm ERR! /root/MagicMirror/config/npm-debug.log root@SmartMirror:~/MagicMirror/config#
This is not a raspberry, is it?
Anyway you are in the wrong folder. You need to go back withcd ..
and runnpm start
in MagicMirror folder -
Thank Man!
