    Can't Start my Magic Mirror
    4 Posts 2 Posters 2.4k Views 2 Watching
    • K
      KnottyCord
      Here is the error that i get when i try to start the mirror with the folowing comand: npm start
      Error here it is!!!
      root@SmartMirror:~/MagicMirror/config# npm start
      > magicmirror@2.1.0 start /root/MagicMirror
      > electron js/electron.js
      npm ERR! Linux 4.4.50-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
      npm ERR! node v6.10.0
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! magicmirror@2.1.0 start: `electron js/electron.js`
      npm ERR! Exit status 1
      npm ERR!
      npm ERR! Failed at the magicmirror@2.1.0 start script 'electron js/electron.js'.
      npm ERR! If you do, this is most likely a problem with the magicmirror package,
      npm ERR! not with npm itself.
      npm ERR!     electron js/electron.js
      npm ERR!     npm bugs magicmirror
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls magicmirror
      npm ERR!     /root/MagicMirror/config/npm-debug.log
      • Y
        yawns Moderator
        This is not a raspberry, is it?
        Anyway you are in the wrong folder. You need to go back with cd .. and run npm start in MagicMirror folder
        • K
          KnottyCord
          Thank Man!
          Y 1 Reply Last reply
          • Y
            yawns Moderator @KnottyCord
            @KnottyCord said in Can’t Start my Magic Mirror:
            Thank Man!
            My pleasure
