    MMM DHT-Sensor Help
    1 Posts 1 Posters 1.9k Views 1 Watching
      STEFF92
      Hi, i’m a totally beginner and the temperature/ humidity sensor is one of my first modules i want to install by myself. Here is the github link:
      https://github.com/bernardpletikosa/MMM-DHT-Sensor
      This were the first things i did:
      pi@raspberrypi:~ $ cd ~/MagicMirror/modules
      pi@raspberrypi:~/MagicMirror/modules $ git clone https://github.com/bernardpletikosa/MMM-DHT-Sensor.git
      Klone nach 'MMM-DHT-Sensor'...
      remote: Counting objects: 18, done.
      remote: Total 18 (delta 0), reused 0 (delta 0), pack-reused 18
      Entpacke Objekte: 100% (18/18), Fertig.
      Prüfe Konnektivität... Fertig.
      pi@raspberrypi:~/MagicMirror/modules $ cd MMM-DHT-Sensor
      pi@raspberrypi:~/MagicMirror/modules/MMM-DHT-Sensor $ npm install
      But then there came these lines:
      npm WARN prefer global node-gyp@3.6.0 should be installed with -g
      > rpi-dht-sensor@0.1.1 install /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor
      > node-gyp rebuild
      make: Entering directory '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/build'
        CC(target) Release/obj.target/node_dht_sensor/src/bcm2835.o
        CXX(target) Release/obj.target/node_dht_sensor/src/node-dht-sensor.o
        SOLINK_MODULE(target) Release/obj.target/node_dht_sensor.node
        COPY Release/node_dht_sensor.node
      make: Leaving directory '/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/rpi-dht-sensor/build'
      > Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall /home/pi/MagicMirror/modules/MMM-DHT-Sensor
      > electron-rebuild -e ../../node_modules/electron-prebuilt
      An unhandled error occurred inside electron-rebuild
      Unable to find electron-prebuilt's version number, either install it or specify an explicit version
      Error: Unable to find electron-prebuilt's version number, either install it or specify an explicit version
          at _callee$ (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/cli.js:74:17)
          at tryCatch (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:63:40)
          at GeneratorFunctionPrototype.invoke [as _invoke] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:337:22)
          at GeneratorFunctionPrototype.prototype.(anonymous function) [as next] (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/babel-runtime/node_modules/regenerator-runtime/runtime.js:96:21)
          at GeneratorFunctionPrototype.tryCatcher (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/util.js:16:23)
          at PromiseSpawn._promiseFulfilled (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/generators.js:97:49)
          at /home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/bluebird/js/release/generators.js:201:15
          at Object. (/home/pi/MagicMirror/modules/MMM-DHT-Sensor/node_modules/electron-rebuild/lib/cli.js:197:4)
          at Module._compile (module.js:570:32)
          at Object.Module._extensions..js (module.js:579:10)
          at Module.load (module.js:487:32)
          at tryModuleLoad (module.js:446:12)
          at Function.Module._load (module.js:438:3)
          at Module.runMain (module.js:604:10)
          at run (bootstrap_node.js:394:7)
          at startup (bootstrap_node.js:149:9)
      npm WARN Magic-Mirror-Module-DHT-Sensor@1.0.0 No repository field.
      npm WARN Magic-Mirror-Module-DHT-Sensor@1.0.0 No license field.
      npm ERR! Linux 4.4.34-v7+
      npm ERR! argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      npm ERR! node v6.10.0
      npm ERR! npm  v3.10.10
      npm ERR! code ELIFECYCLE
      npm ERR! Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall: `electron-rebuild -e ../../node_modules/electron-prebuilt`
      npm ERR! Exit status 255
      npm ERR!
      npm ERR! Failed at the Magic-Mirror-Module-DHT-Sensor@1.0.0 postinstall script 'electron-rebuild -e ../../node_modules/electron-prebuilt'.
      npm ERR! If you do, this is most likely a problem with the Magic-Mirror-Module-DHT-Sensor package,
      npm ERR! not with npm itself.
      npm ERR!     electron-rebuild -e ../../node_modules/electron-prebuilt
      npm ERR!     npm bugs Magic-Mirror-Module-DHT-Sensor
      npm ERR! Or if that isn't available, you can get their info via:
      npm ERR!     npm owner ls Magic-Mirror-Module-DHT-Sensor
      npm ERR!     /home/pi/MagicMirror/modules/MMM-DHT-Sensor/npm-debug.log
      The way i connected the dht11 sensor is shown in the following picture:
      alt text
      I dont know what i did wrong, can anyone help me please?
