    MMM-AlexaPi
    48 Posts 8 Posters 41.2k Views 9 Watching
    • romainR Offline
      romain
      @lucallmon Oh. My mistake then. So… AlexaPi is for MMM-alexa or MMM-alexapi ?
      I am confused.
      lucallmonL 1 Reply Last reply Reply Quote 0
      • lucallmonL Offline
        lucallmon @romain
        @romain AlexaPi is a separate program from MM. It can be found here: https://github.com/alexa-pi/AlexaPi. Once installed and working properly, you can access it through MM with the MMM-AlexaPi module, found here: https://github.com/dgonano/MMM-AlexaPi. This is the only easy [somewhat] to install version that is voice activated and works every time. The other ones, I have been unable to get to work because there is no step-by-step guide.
        romainR 1 Reply Last reply Reply Quote 1
        • romainR Offline
          romain @lucallmon
          @lucallmon Ok, I will try it tomorrow. I have already installed AlexaPi. I though it was for the MMM-alexa module though. Anyway, thanks for the input.
          johnnyboyJ 1 Reply Last reply Reply Quote 0
          • johnnyboyJ Offline
            johnnyboy @romain
            This post is deleted!
            romainR 1 Reply Last reply Reply Quote 0
            • romainR Offline
              romain @johnnyboy
              @johnnyboy Yeah I saw, I installed it in my home folder the first time before facepalming
                johnnyboy @lucallmon
                  bminer1
                  I’m getting a permission denied when trying to save after making the changes in /etc/opt/AlexaPi/config.yaml
                  I feel like ive fallen in a rabbit whole that may be alittle over my abilities.
                  • romainR Offline
                    romain @bminer1
                    @bminer1 That’s normal, there is multiple type of user in linux with different level of permission, it’s for safety (that you or a virus doesn’t destroy your operating system). When you are connected to your regular user (pi if you are using raspbian) you have only access in writing to your home folder. However, the pi user is also a “sudo” user, which mean that you can get higher permission in exchange of providing the right password (which is your regular password in raspbian).
                    To do that you write sudo your_command , for example sudo nano /etc/opt/AlexaPi/config.yaml . you’ll be ask to enter a password and then you can edit your file.
                    It’s like being administrator on windows, but with a password instead of a window that ask you if you want to run as administrator
                    • 3 / 3
