    How do I add a Google Birthday Calendar
    3 Posts 3 Posters 3.7k Views 3 Watching
      jasondreher
      I have multiple calendars in my MM from the ics link in google working fine, but the birthday calendar does not have a ics link. Is there any other way to add this?
      This calendar is pulling the birthday from contacts. Below is a partial screen shot where the ICAL link would be.
      0_1490903050744_upload-8c420a53-0c0c-4004-a195-2993990910be
      • FistandantilusF Offline
        Fistandantilus
        Hi, did you find a solution for this?
          blueeyed1
          Hi, i found a way how to do it but still it’s not automatic updated calendar.
          1. Select Settings (Calendar settings in Google Calendar).
          2. Go to the Calendars tab.
          3. Follow the Export calendar link under My Calendars (You will get Birthday calendar in ics format)
            Next steps are optional
          4. Create new calendar
          5. Select Settings (Calendar settings in Google Calendar).
          6. Go to the Calendars tab.
          7. Follow the Import calendar link under My Calendars
          8. Select your new calendar
          9. Now you can use your public or private adress for modules
