How do I add a Google Birthday Calendar
I have multiple calendars in my MM from the ics link in google working fine, but the birthday calendar does not have a ics link. Is there any other way to add this?
This calendar is pulling the birthday from contacts. Below is a partial screen shot where the ICAL link would be.
Hi, did you find a solution for this?
Hi, i found a way how to do it but still it’s not automatic updated calendar.
- Select
Settings(Calendar settings in Google Calendar). - Go to the
Calendars tab. - Follow the
Export calendarlink under My Calendars (You will get Birthday calendar in ics format)
Next steps are optional - Create new calendar
- Select
Import calendarlink under My Calendars - Select your new calendar
- Now you can use your public or private adress for modules
- Select
