    2.1.1 Update Error Install/postinstall cannot run & grunt-yamllint@0.2.0 error. Screenshot.
    5 Posts 3 Posters 2.6k Views 3 Watching
      Mar
      Tried to update to 2.1.1 and am getting the following error. At first the install failed with some access issues so i tried with sudo and am now getting this error. I’m not really sure what the “cannot run in wd” means.
      daenickD 1 Reply Last reply Reply Quote 0
      • daenickD Offline
        daenick @Mar
        @Mar check this: http://stackoverflow.com/questions/18136746/npm-install-failed-with-cannot-run-in-wd
          Mar
          @daenick thanks for the pointer, will try it out now and report back.
            AAPS @Mar
            @Mar What happens when you try npm start?
              Mar
              @daenick alright looks like your tip worked…i think. I’m still getting the following error but showing it was installed successfully
              npm WARN grunt-yamllint@0.2.0 requires a peer of grunt@~0.4.0 but none was installed.
              Does this mean installation was actually successful or do i need to update/install something else?
              @AAPS when i try npm start i get the following:
              > magicmirror@2.1.1 start /home/pi/MagicMirror
              > sh run-start.sh
