    Black mirror after update
    3 Posts 2 Posters 2.6k Views 2 Watching
    • Y Offline
      yakko2001
      Hey, after an update i got a black mirror.
      i did:
      git pull
      sudo npm install
      npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/pi/MagicMirror
      npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/pi/MagicMirror
      • I tried to use the config.js sample
      • git reset --hard
      • pm2 logs mm
      0|mm       | Connecting socket for: newsfeed
      0|mm       | Starting module: newsfeed
      0|mm       | Sockets connected & modules started ...
      0|mm       | Launching application.
      /home/pi/.pm2/logs/mm-error-0.log last 15 lines:
      0|mm       |
      0|mm       | ERROR! Could not find main module js file.
      0|mm       | error: kann .git/FETCH_HEAD nicht öffnen: Keine Berechtigung
      0|mm       |
      0|mm       |
      0|mm       |
      0|mm       |
      0|mm       |
      0|mm       |
      What i do wrong?
      Thank you in advanced for any kind of help!!
        d3r
        Same issue here. I’ll try a new config later.
        • Y Offline
          yakko2001
          Solved!!
          npm install --unsafe-perm
          did the trick.
