MMM-MirrorMirrorOnTheWall expection
Hello, I got the exception when using the MMM-MirrorMirrorOnTheWall Module
Here is my logs:0|mm | Whoops! There was an uncaught exception... 0|mm | { Error: write EPROTO 1950990336:error:14094416:SSL routines:ssl3_read_bytes:sslv3 alert certificate unknown:../../vendor/node/deps/openssl/openssl/ssl/s3_pkt.c:1472:SSL alert number 46 0|mm | 1950990336:error:1409E0E5:SSL routines:ssl3_write_bytes:ssl handshake failure:../../vendor/node/deps/openssl/openssl/ssl/s3_pkt.c:656: 0|mm | at exports._errnoException (util.js:1026:11) 0|mm | at WriteWrap.afterWrite (net.js:795:14) code: 'EPROTO', errno: 'EPROTO', syscall: 'write' }'"
I do have an internet connection for sure. I have the folder “certs” . Here is my MMM-MirrorMirrorOnTheWall folder achitecture.
. ├── certs │ ├── keys.json │ ├── keys_sample.json │ ├── MagicMirror.cert.pem │ ├── MagicMirror.private.key │ ├── MagicMirror.public.key │ └── root-CA.crt ├── LICENSE.txt ├── MirrorMirror.js ├── MMM-MirrorMirrorOnTheWall.css ├── MMM-MirrorMirrorOnTheWall.js ├── ModuleNames.json ├── node_helper.js ├── node_modules ├── package.json
(The node_modules have a lot of folder in it so I chose not to past the content of it here for better visibility)
What does this exception mean ? How can I solve it ?
Ok, turned out It was a silly mistake, I forget to change the region in the MirrorMirror.js.
I don’t have that exception anymore.
However, even though the module launch without crash, nothing is happening. I say to my mic “Alexa on the wall” but nothing is happening. (The log doesn’t say anything). Any idea why ?
