    My own fonts
    9 Posts 3 Posters 4.5k Views 2 Watching
    • Z Offline
      zkab
      How can I load & use my own fonts in MM ?
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @zkab
        @zkab you can set the font in custom.css
        • Z Offline
          zkab
          I have my own font ‘SHOTGUNK.TTF’ that I want to use in ‘helloworld’ … don’t figure out the syntax in custom.css
            broberg Project Sponsor @zkab
            @zkab
             @font-face {
              font-family: shotgunk;
              font-style: normal;
              font-weight: 400;
              src:
                local("shotgunk"),
                url("../fonts/shotgunk/SHOTGUNK.TTF") format("truetype");
            • Z Offline
              zkab
              OK - I will place the code in custom.css but where do I store the actual font “SHOTGUNK.TTF” … in the MagicMirror/fonts subdir ?
                @zkab Yes, I placed my fonts in separate folders as well to keep it organized (doesn’t matter as long as the url in the css code goes to the font in question)
                • Z Offline
                  zkab
                  Didn’t get it right …
                  What I want to do is write two textlines with ‘helloword’ - the first one with ‘upper_third’ and the second one with ‘bottom_bar’.
                  Fonts should be zapfchan (‘upper_third’) and shotgunk (‘bottom_bar’) but only ‘upper_third’ is OK.
                  I have place the fonts in a folder my-fonts …
                  :~/MagicMirror/fonts/my_fonts $ ls -l
                  total 96
                  -rwxr-xr-x 1 pi pi 34276 apr 6 15:32 SHOTGUNN.TTF
                  -rwxr-xr-x 1 pi pi 59964 apr 6 15:51 ZAFCHAB.TTF
                  My custom.css looks like this:
                  @font-face {
                    font-family: zapfchan;
                    font-style: normal;
                    font-weight: 400;
                    src:
                      local("zapfchan"),
                      url("../fonts/my_fonts/ZAFCHAB.TTF") format("truetype");
                  @font-face {
                    font-style: normal;
                    font-weight: 400;
                    src:
                      local("shotgunk"),
                      url("../fonts/my_fonts/SHOTGUNK.TTF") format("truetype");
                  .region.upper.third .helloworld div {
                  font-size: 71px;
                  color: #74bbf1;
                  font-family: "zapfchan";
                  font-style: normal;
                  .region.bottom .helloworld div {
                  font-size: 100px;
                  color: #74bbf1;
                  font-family: "shotgunk";
                  font-style: normal;
                  Where have I missed ?
                    doublecheck your spelling, you have SHOTGUNN.TTF and SHOTGUNK.TTF … Which is the correct filename?
                    • Z Offline
                      zkab
                      Thanks - I didn’t saw the misspell … sorry
                      The font is SHOTGUNN.TTF and nothing else.
                      Problem is solved and thanks again.
