    Black Screen after Launching application.
    13 Posts 5 Posters 11.9k Views 5 Watching
      dhirajv12
      When i start the console
      With npm start dev following errors are found
      Uncaught reference error: moment is not defined
      At Class.getDom (clock.js:77)
      At updateDom (main.js:99)
      at Object.updateDom (main.js:470)
      at Class.updateDom (module.js:291)
      at clock.js:45
      Need help I am stuck
        dhirajv12 @dhirajv12
        @dhirajv12
        For the black screen proble, I even did the git pull to update
        git pull https://github.com/MichMich/MagicMirror
        From https://github.com/MichMich/MagicMirror
        • branch HEAD -> FETCH_HEAD
          Already up-to-date.
        Now where is the issue??? Stuck please help
        • bheplerB Offline
          bhepler Module Developer @dhirajv12
          @dhirajv12 Let’s double-check some things. Please enter the following.
          cd ~/MagicMirror
          rm -rf modules/aiclient
          git pull
          npm install
          cp config/config.js.sample config/config.js
          npm start
          With luck, that should at the very least get you a basic interface with the calendar, clock, compliments and newsfeed.
          @dhirajv12 said in Black Screen after Launching application.:
          In the terminal it says
          No helper found for module: clock
          no helper found for module: complements
          This is normal. The system is checking for a node_helper.js file for every module. Those modules do not have one, so it is reported as such during the startup process.
