    NPM start not running but Localhost8080 is
    1 Posts 1 Posters 1.1k Views 1 Watching
    • U
      undergroundauth
      When i run command ‘npm install && node serveronly’
      the mirror works on localhost8080
      but when i run the command ‘npm start’ i get this error
      Please help … is there any step i am missing
      magicmirror@2.1.1 start /home/pi/MagicMirror
      sh run-start.sh
      /home/pi/MagicMirror/node_modules/electron/index.js:9
      throw new Error(‘Electron failed to install correctly, please delete node_modules/’ + path.basename(__dirname) + ’ and try installing again’)
      Error: Electron failed to install correctly, please delete node_modules/electron and try installing again
      at Object. (/home/pi/MagicMirror/node_modules/electron/index.js:9:9)
      at Module._compile (module.js:570:32)
      at Object.Module._extensions…js (module.js:579:10)
      at Module.load (module.js:487:32)
      at tryModuleLoad (module.js:446:12)
      at Function.Module._load (module.js:438:3)
      at Module.require (module.js:497:17)
      at require (internal/module.js:20:19)
      at Object. (/home/pi/MagicMirror/node_modules/electron/cli.js:3:16)
