    Ability to change color by physical button?
    13 Posts 3 Posters 8.7k Views 3 Watching
    • strawberry 3.141S Offline
      https://www.raspberrypi.org/learning/physical-computing-with-python/ maybe this can help you to understand how the gpio pins work, but it’s a different programmin language as in this project
        Snoevit
        The python-button part is something i tried before, its the other language i have great difficulties with. (The one that MagicMirror is coded in.) since i dont understand The language, i cant read it and change/re-write what is needed for my idea to work. Ive been trying for 4h now.
          if you post your code in here we may can assist you a little bit
            Snoevit
            I dont have any code. All this time i have been trying to understand what i am trying to do. If we look at The code from PIR-sensor, i dont know wich line are doing what. I have no clue on how and where to start. I cant see to understand The “building” of a module. All The “this. File” and what not dont make Any sense to me.
            I need a How-to guide for toddlers :P
              i hope the following lines can help you to understand it a bit more and that it is explained correctly.
              this references the module itself
              so in the module you can do this.sendSocketNotification(…) which will call the function sendsocketnotification of your module (this)
              also you can follow this guide to develop a module https://github.com/MichMich/MagicMirror/tree/master/modules
              /* Magic Mirror
               * Module: MMM-PIR-Sensor
               * By Paul-Vincent Roll http://paulvincentroll.com
               * MIT Licensed.
              /* registers a module with the name MMM-PIR-Sensor in the magic mirror system*/
              Module.register('MMM-PIR-Sensor',{
                      /*config part*/
              	defaults: {
              		sensorPIN: 22, /*number of pin can be different for raspberry pi version e.g. https://raspilab.files.wordpress.com/2014/08/gpiosb.png*/
              		relayPIN: false, /*this is for using relais in this module not needed because you can also set the hdmi output off*/
              		powerSaving: true,
              		relayOnState: 1, /*not important because you're not using relays*/
                      /*here you receive messages which you send via node_helper.js*/
              		if (notification === "USER_PRESENCE"){
                                      /*when you receive the notification user_presence from your node_helper you send a global message with this notification to every module in magic mirror so they can handle this event as well*/
              			this.sendNotification(notification, payload)
                      /*this method got fired when the core is starting your module
              	start: function() {
                              /* the following 6 lines can be removed if you don't want to use relais. The functionality of these lines is to set relayoffstate depending on the relayonstate defined in the configt section above*/
              		if (this.config.relayOnState == 1){
              			this.config.relayOffState = 0
              		else if (this.config.relayOnState == 0){
              			this.config.relayOffState = 1
                              /*here you send a notification to your node_helper.js*/
              		this.sendSocketNotification('CONFIG', this.config);
                               /*here you print some information to the console, which you can't se without enabling the developer console in the electronh wrapper during runtime*/
              		Log.info('Starting module: ' + this.name);
                i was to late to edit :pensive:
                'use strict';
                /* Magic Mirror
                 * MIT Licensed.
                /*import dependencies*/
                const NodeHelper = require('node_helper');
                const gpio = require('wiring-pi');
                const exec = require('child_process').exec;
                  /*this method got fired when the core is starting your module helper*/
                  start: function () {
                    this.started = false
                  /*this function will activate your monitor by enabling hdmi output or sending a signal to the relais via gpio pin*/
                  activateMonitor: function () {
                    /* you don't need the following 3 lines, which would set a signal to the relais specified in the config section of your module of the file above*/
                    if (this.config.relayPIN != false) {
                      gpio.digitalWrite(this.config.relayPIN, this.config.relayOnState)
                    /*after removing the previous 3 lines you also need to change "else if" to "if". the following lines run a command in a child process in the background to enable the hdmi output*/
                    else if (this.config.relayPIN == false){
                      exec("/opt/vc/bin/tvservice -p", null);
                /*this function will deactivate your monitor by disabling hdmi output or sending a signal to the relais via gpio pin*/
                  deactivateMonitor: function () {
                      gpio.digitalWrite(this.config.relayPIN, this.config.relayOffState)
                 /*after removing the previous 3 lines you also need to change "else if" to "if". the following lines run a command in a child process in the background to disable the hdmi output*/
                      exec("/opt/vc/bin/tvservice -o", null);
                  /*here you receive messages which you send via modulename.js*/
                    const self = this;
                    /*the following part runs when you receive the notification from your module l. 33 on github "this.sendSocketNotification('CONFIG', this.config);"*/
                    if (notification === 'CONFIG' && this.started == false) {
                      const self = this
                      this.config = payload
                      //Setup pins
                      exec("echo '" + this.config.sensorPIN.toString() + "' > /sys/class/gpio/export", null); /*motion sensor pin*/
                      exec("echo 'in' > /sys/class/gpio/gpio" + this.config.sensorPIN.toString() + "/direction", null); /*relais pin*/
                      /*fllowing lines not important if you're not using relais*/
                      if (this.config.relayPIN) {
                        exec("echo '" + this.config.relayPIN.toString() + "' > /sys/class/gpio/export", null);
                        exec("echo 'out' > /sys/class/gpio/gpio" + this.config.relayPIN.toString() + "/direction", null);
                        exec("echo '1' > /sys/class/gpio/gpio" + this.config.relayPIN.toString() + "/value", null);
                      //Set gpio-mode
                      gpio.setup('sys');
                      //Detected movement
                      /*when you detect a movement with your sensor it will run the callback "function(delta){...}"*/
                      gpio.wiringPiISR(this.config.sensorPIN, gpio.INT_EDGE_BOTH, function(delta) {
                        if (gpio.digitalRead(self.config.sensorPIN) == 1) {
                          /* motion detected send the notification to your module*/
                          self.sendSocketNotification("USER_PRESENCE", true);
                          if (self.config.powerSaving){
                            /*activate the monitor again to show the user data on your screen*/
                            self.activateMonitor()
                        //No movement
                        else if (gpio.digitalRead(self.config.sensorPIN) == 0) {
                          /*send your module the notification tha there is no user present and deactivate the monitor*/
                          self.sendSocketNotification("USER_PRESENCE", false);
                            self.deactivateMonitor()
                    this.started = true
                  Snoevit
                  Thank you Strawberry with everything.
                  I think i have to give this idea up tho. I have now been sitting for two days trying. But i just cant wrap my head around it. :/
                  Nothing makes sense for me with JavaScript. Not a single row of code have i been able to write.
                  Changing ‘fontColor’ is about my level of knowledge :P
                    maybe this will give you a start
                    I added the following lines to MagicMirror/css/custom.css
                    .male {
                    	background: black;
                    	color: blue;
                    .female {
                    	background: white;
                    	color: pink;
                    and for testing I edited the clock module (MagicMirror/modules/default/clock/clock.js) because it get’s updated every second.
                    put those lines right after line 69
                    if(secondsWrapper.innerHTML % 10 == 0){ /*changes class every 10 seconds, because i don't have a button i made this "hack" for testing purposes*/
                    			var body = document.querySelector('body');
                    			if(body.classList.contains("male")){
                    				body.classList.remove("male");
                    				body.classList.add("female");
                    			} else {
                    				body.classList.remove("female");
                    				body.classList.add("male");
                    • EoFE Offline
                      EoF
                      Hi… This can easily be accomplished with some javascript and css. No need to mess with hardware or anything.
                      Edit: I guess I should actually read the post. You need a physical button. Disregard lol
