    AlexaPi
    28 Posts 4 Posters 16.7k Views 4 Watching
      davidrq7 @johnnyboy
      @johnnyboy dunno why, guess i make a mistake. but now i reinstall AlexaPi and make everythink step by step and i have error when i use to use my LocalIp:5050 0_1492682163943_error.jpg
      johnnyboyJ 1 Reply Last reply Reply Quote 0
      • johnnyboyJ Offline
        johnnyboy @davidrq7
        This post is deleted!
          davidrq7 @johnnyboy
          @johnnyboy ill wait mby it will be ok. But i found at forum somethink like this" Description of problem:
          If you already have a config file the installer will ask if you want to Keep, Edit or Delete, choosing Keep it does exit the installer even if there is no token saved in the config file. You need to run manually python auth_web.py to finish the configuration."
          Do you think it will help it this case? How should i run it btw?
            johnnyboy @davidrq7
              johnnyboy @johnnyboy
                davidrq7 @johnnyboy
                @johnnyboy thx so ill just wait for Amazon response . Thx for Your time!
                  johnnyboy @davidrq7
                    • romainR Offline
                      romain
                      Not completly sure about this but the http server : 5055 might just be the port AlexaPi using to comunicate with the MagicMirror module MMM-AlexaPi . I do have the same message and it doesn’t prevent AlexaPi to work
                        davidrq7
                        Guys i get a little succes.
                        I got the token from amazon, i set the sound and when i start alexa service she is active but i got rly nasty problem with this port 5055. I have no idea what to do next0_1492711999352_18034766_1562333477133204_1450890660_n.jpg
                        romainR 1 Reply Last reply Reply Quote 0
                        • 3 / 3
