    AlexaPi
    28 Posts 4 Posters 19.4k Views 4 Watching
    • romainR
      romain
      Not completly sure about this but the http server : 5055 might just be the port AlexaPi using to comunicate with the MagicMirror module MMM-AlexaPi . I do have the same message and it doesn’t prevent AlexaPi to work
        davidrq7
        Guys i get a little succes.
        I got the token from amazon, i set the sound and when i start alexa service she is active but i got rly nasty problem with this port 5055. I have no idea what to do next0_1492711999352_18034766_1562333477133204_1450890660_n.jpg
        romainR 1 Reply Last reply
        • romainR
          romain @davidrq7
          @davidrq7 This mean you have already an instance of alexaPi running. reboot or kill the already running alexapi
            davidrq7
            Y, but even when i stop alexa service and start it again it looks all the same. Any sugestions? :) im getting closer to the end ^^
            johnnyboyJ 1 Reply Last reply
            • johnnyboyJ
              johnnyboy @davidrq7
              D 1 Reply Last reply
                davidrq7 @johnnyboy
                @johnnyboy i’ll check this tomorrow by using sudo netstat -lnptu to check which application is blocking 5055 or 5050 port
                • johnnyboyJ
                  johnnyboy @davidrq7
                  • lucallmonL
                    lucallmon
                    i had errors installing the current version 1.5, so I reverted back to v1.4 which is much more stable. this is the version that I am currently running flawlessly.
                    cd /opt/AlexaPi
                    sudo git checkout v1.4
                    I hope this helps
                    • johnnyboyJ
                      johnnyboy @lucallmon
                        davidrq7
                        This is what i got when i used netstat. Dont know what should i do next?
                        0_1492777811244_18052991_1563534897013062_29793805_n.jpg0_1492778637066_18052791_1563556803677538_1550604459_n.jpg0_1492778810487_1563565440343341_1253734879_n.jpg
                        Edit: Allright i found something. sudo nano /etc/opt/AlexaPi/config.yaml at bottom is a line with numer 5055 so i change it for 5050. Diging more …;)
                          davidrq7
                          Found another intresting thing at forum.
                          “I’m expecting there’s a significance in which user is starting AlexaPi.
                          The service is started by user alexapi, but when you start it from the terminal, with “sudo”, you’re starting it as root.”
                          How can i use it? In super newbie …
                          • romainR
                            romain @davidrq7
                            @davidrq7 Wait, are you still on your connexion issue ? Or it’s a sound issue ? Because the user might be an issue for the sound, but it’s unlickly to be an issue for the connexion
                              davidrq7 @romain
                              @romain i think i wilk leave this version. Can You tell me how to install AlexaPi 1.4 plz ?
                              • romainR
                                romain @davidrq7
                                @davidrq7 Sure, you go to your AlexPi folder
                                cd /opt/AlexaPi/
                                Then you use the command git checkout v1.4
                                (you could have write git checkout then press the tab key once or two time so it show you all available version. This work for most github repository)
                                  davidrq7
                                  Guys AlexaPi is conecting but i have an issue with sound i cant record any sound.
                                  When i use arecord -D yourdevice test.wav
                                  here’s my alsa link
                                  http://www.alsa-project.org/db/?f=13c96d7203793e608733957776c725f8a536602f
                                  What i should do next??
                                  lucallmonL 1 Reply Last reply
                                  • lucallmonL
                                    lucallmon @davidrq7
                                    @davidrq7 go to gitter.im/AlexaPi and ask there. This is where the guys that made it hang out.
