Python - One momentary switch, LED, and a shut-off timer
3 Posts 1 Posters 4.2k Views 1 Watching
  • U Offline
    Unbored
    Working on programming a LED strip lights around the mirror, with a single push button. I am good with the GPIOs and the relay required, but seeking some guidance on the code
    • First button press: Lights activate. Have the option to move to the second button press or if the button is not pressed a second time, then the side lights will turn off automatically after 30 minutes.
    • Second button press: Lights turn off and python is waiting for the first button press (again).
    Below is one version that I been working on where I wanted to divide the lights (side lights (“low”), then side&top lights (“high”), then all off), but at this point I would settle for just all lights at the same time.
    The auto-shutoff is required to ensure they aren’t left on for days at time. :-)
    It is possible that I need to pull in another module, but I can’t seem to hack my way into figuring out the shutoff timer or where to place it, so it is time to call in a lifeline. Thanks.
    import RPi.GPIO as GPIO
    from time import sleep
    GPIO.setmode(GPIO.BCM)
    LEDPinLow = 26
    LEDPinHigh = 22
    buttonPin = 5
    # Setup the pin the LED is connected to
    GPIO.setup(LEDPinLow, GPIO.OUT)
    GPIO.setup(LEDPinHigh, GPIO.OUT)
    # Setup the button
    GPIO.setup(buttonPin, GPIO.IN, pull_up_down = GPIO.PUD_UP)
    buttonPress = True
    ledStateLow = False
    ledStateHigh = False
    while (1):
            print("Press it")
            buttonPress = GPIO.input(buttonPin)
            if buttonPress == False and ledStateLow == False and ledStateHigh == False:
                GPIO.output(LEDPinLow, True)
                GPIO.output(LEDPinHigh, False)
                print("LED ON - Side lights only")
                ledStateLow = True
                sleep(.25)
            elif buttonPress == False and ledStateLow == True and ledStateHigh == False:
                GPIO.output(LEDPinHigh, True)
                print("LED ON - Side and Top Lights ")
                ledStateLow = True
                ledStateHigh = True
                sleep(0.25)
            elif ledStateLow == True and ledStateHigh == True:
                sleep(5)
                GPIO.output(LEDPinLow, False)
                print("LEDs OFF")
                ledStateLow = False
                sleep(0.5)
            sleep(0.15)
    • U Offline
      Unbored
      Re: Python - One momentary switch
      I found the answer over on stackexchange and figured I would share. The mirror is a college graduation present for my youngest daughter; she requested the light ring (I heard the word make-up followed by blah, blah, blah, blah…, kidding of course.). The 30 minute timer was not a joke, there’s no way I am leaving responsibility of turning off the light to a college grad :face_palm_tone2:
      I am still working on it and will post a thread in the correct forum when it is done.
      The answers are here: https://raspberrypi.stackexchange.com/questions/66639/python-one-momentary-switch-led-and-a-shut-off-timer?answertab=active#tab-top
      #!/usr/bin/env python
      import time
      import pigpio
      LEDPin = 26
      buttonPin = 5
      LEDOn = False
      minutesOn = 0
      def callback(gpio, level, tick):
         global minutesOn, LEDOn
         if level == 0: # button press
            if LEDOn:
               print("LED off")
               LEDOn = False
               pi.write(LEDPin, 0)
            else:
               print("LED on")
               LEDOn = True
               pi.write(LEDPin, 1)
               minutesOn = 0
         elif level == pigpio.TIMEOUT:
            if LEDOn:
               minutesOn += 1
               print("LED on for {} minutes".format(minutesOn))
               if minutesOn >= 30:
                  print("LED off")
                  LEDOn = False
                  pi.write(LEDPin, 0)
      pi = pigpio.pi()
      if not pi.connected:
         exit()
      pi.set_mode(LEDPin, pigpio.OUTPUT)
      # Setup the button
      pi.set_mode(buttonPin, pigpio.INPUT)
      pi.set_pull_up_down(buttonPin, pigpio.PUD_UP)
      pi.set_glitch_filter(buttonPin, 5000)
      pi.set_watchdog(buttonPin, 60000)  # watchdog every minute
      cb = pi.callback(buttonPin, pigpio.EITHER_EDGE, callback)
      while True: # all the work is done in the callback
         time.sleep(1)
      • U Offline
        Unbored
        Here’s a pic of the work in progress.
        alt text
