    Electron NPM Error
    28 Posts 7 Posters 24.1k Views 7 Watching
    • NomisN Offline
      Nomis @DeanoAus
      @DeanoAus
      Sorry to hear that.
      For me it worked with those dependencies fixed.
      pi@raspberrypi:~$ npm -v ; node -v
      4.1.2
      v7.7.1
      pi@raspberrypi:~$ cd MagicMirror/
      pi@raspberrypi:~/MagicMirror$ cd node_modules/
      pi@raspberrypi:~/MagicMirror/node_modules$ npm install electron
      > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
      > node install.js
      magicmirror@2.1.1 /home/pi/MagicMirror
      └── electron@1.6.6
      Here the thread I’ve been looking last night: https://github.com/electron/electron/issues/9324
      User: johannesjo made a fork: https://github.com/johannesjo/electron-prebuilt
      But what I did was to downgrade the extract-zip:
      pi@raspberrypi:~/MagicMirror/node_modules$ npm uninstall extract-zip
      pi@raspberrypi:~/MagicMirror/node_modules$ npm install extract-zip@1.6.0
      As a result of all this:
      pi@raspberrypi:~/MagicMirror$ npm install
      > magicmirror@2.1.1 install /home/pi/MagicMirror
      > cd vendor && npm install
      magicmirror-vendors@ /home/pi/MagicMirror/vendor
      ├── font-awesome@4.7.0
      ├── moment@2.18.1
      ├── moment-timezone@0.5.13
      └── weathericons@2.1.0
      > magicmirror@2.1.1 postinstall /home/pi/MagicMirror
      > sh installers/postinstall/postinstall.sh
      MagicMirror installation successful!
      Hope it helps
      loading…
        DeanoAus
        now it’s just hanging at the install of electron. Been there for 5 minutes now :(
        pi@Pi:~/MagicMirror $ cd node_modules/
        pi@Pi:~/MagicMirror/node_modules $ sudo npm uninstall extract-zip
        - ms@0.7.1 node_modules/extract-zip/node_modules/ms
        - debug@2.2.0 node_modules/extract-zip/node_modules/debug
        - pend@1.2.0 node_modules/pend
        - fd-slicer@1.0.1 node_modules/fd-slicer
        - yauzl@2.4.1 node_modules/yauzl
        - extract-zip@1.6.4 node_modules/extract-zip
        npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
        pi@Pi:~/MagicMirror/node_modules $ sudo npm install extract-zip@1.6.0
        └─┬ spectron@3.6.2
          └─┬ electron-chromedriver@1.6.0
            └─┬ extract-zip@1.6.0
              ├─┬ concat-stream@1.5.0
              │ └─┬ readable-stream@2.0.6
              │   └── isarray@1.0.0
              ├── debug@0.7.4
              └─┬ yauzl@2.4.1
                └─┬ fd-slicer@1.0.1
                  └── pend@1.2.0
        pi@Pi:~/MagicMirror/node_modules $ sudo npm install electron
        > node install.js
          DeanoAus
          Soon as I wrote that…
          > node install.js
          └── electron@1.6.6
            DeanoAus
            pi@Pi:~/MagicMirror $ sudo npm install
            npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/pi/MagicMirror
            npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/pi/MagicMirror
            • NomisN Offline
              Nomis
              I ran into some trouble myself after installing the MMM-PIR-Sensor (the whole MM is not starting :D )
              Mental Note: Remember to BackUp stable builds!
              I don’t see the need of using sudo for npm install.
              I’ve tried to replicate your error(took a while to undo the fixes):
              npm list
              npm ERR! extraneous: gulp-stylelint@3.9.0 /home/pi/MagicMirror/node_modules/gulp-stylelint
              npm ERR! extraneous: stylelint@7.8.0 /home/pi/MagicMirror/node_modules/stylelint
              npm purge
              npm rebuild
              got this: coffee-script@1.10.0 should be installed with -g // npm WARN prefer global jsonlint@1.6.2 should be installed with -g
              cd /MagicMirror/node_modules/
              npm install  coffee-script@1.10.0 -g
              npm install jsonlint@1.6.2 -g
              npm install stylelint
              npm install colorguard@1.2.0 -g
              npm list (again yes)
              you will get an error: npm ERR! extraneous: stylelint@7.10.1 /home/pi/MagicMirror/node_modules/stylelint because we instaleld manually.
              Give it a try and let us know.
              loading…
                DeanoAus
                Holy crap, that worked. I’m back in business!
                1000 camels to you, good sir!
                NomisN 1 Reply Last reply Reply Quote 1
                • NomisN Offline
                  Nomis @DeanoAus
                  @DeanoAus
                  You are welcome and glad it works!
                  loading…
                  • F Offline
                    froinds
                    They fixed the issue with extract-zip. Thanks.
