    Electron NPM Error
    28 Posts 7 Posters 26.2k Views 7 Watching
      DeanoAus
      73493 silly postinstall electron@1.6.6
      73494 info lifecycle electron@1.6.6~postinstall: electron@1.6.6
      73495 verbose lifecycle electron@1.6.6~postinstall: unsafe-perm in lifecycle false
      73496 verbose lifecycle electron@1.6.6~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modul$
      73497 verbose lifecycle electron@1.6.6~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron
      73498 silly lifecycle electron@1.6.6~postinstall: Args: [ '-c', 'node install.js' ]
      73499 silly lifecycle electron@1.6.6~postinstall: Returned: code: 1  signal: null
      73500 info lifecycle electron@1.6.6~postinstall: Failed to exec postinstall script
      73501 verbose unlock done using /root/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
      73502 silly rollbackFailedOptional Starting
      73503 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73504 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
      73505 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73506 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
      73507 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73508 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
      73509 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73510 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
      73511 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73512 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
      73513 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
      73527 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73528 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73529 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73530 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73531 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73532 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73533 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73534 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
      73535 silly rollbackFailedOptional Finishing
      73536 silly runTopLevelLifecycles Finishing
      73537 silly install printInstalled
      73538 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
      73539 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
      73540 verbose stack Error: electron@1.6.6 postinstall: `node install.js`
      73540 verbose stack Exit status 1
      73540 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:279:16)
      73540 verbose stack     at emitTwo (events.js:106:13)
      73540 verbose stack     at EventEmitter.emit (events.js:191:7)
      73540 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
      73540 verbose stack     at ChildProcess.emit (events.js:191:7)
      73540 verbose stack     at maybeClose (internal/child_process.js:886:16)
      73540 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
      73541 verbose pkgid electron@1.6.6
      73542 verbose cwd /home/pi/MagicMirror
      73543 verbose Linux 4.9.24-v7+
      73544 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
      73545 verbose node v6.10.2
      73546 verbose npm  v4.5.0
      73547 error code ELIFECYCLE
      73548 error errno 1
      73549 error electron@1.6.6 postinstall: `node install.js`
      73549 error Exit status 1
      73550 error Failed at the electron@1.6.6 postinstall script 'node install.js'.
      73550 error Make sure you have the latest version of node.js and npm installed.
      73550 error If you do, this is most likely a problem with the electron package,
      73550 error not with npm itself.
        mitchscobell
        I am having the same problem. Wiped the pi and reflashed the image from scratch. Spent a few hours myself tonight trying various things to fix it without getting anywhere. Same exact errors as pasted above.
        • W
          WinterRain
          I’m getting the same problem. Started from scratch a few times but no luck. Finally managed to have it installed to the point where I could run using node serveronly then running on a browser. Also had to use ~/MagicMirror/vendor npm install as this seem to have been skipped in the auto installation when it hit the electron error.
            DeanoAus
            Is there any way we can get a dev to look at this?
              DeanoAus
              I installed npm in Vendors. Now my error log is significantly less, but still dies.
              1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
              2 info using npm@4.5.0
              3 info using node@v6.10.2
              5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
              6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
              7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
              8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
              9 verbose lifecycle magicmirror@2.1.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin$
              10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
              11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
              12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
              13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
              13 verbose stack spawn ENOENT
              13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
              13 verbose stack     at emitTwo (events.js:106:13)
              13 verbose stack     at ChildProcess.emit (events.js:191:7)
              13 verbose stack     at maybeClose (internal/child_process.js:886:16)
              13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
              14 verbose pkgid magicmirror@2.1.1
              15 verbose cwd /home/pi/MagicMirror
              16 verbose Linux 4.9.24-v7+
              17 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
              18 verbose node v6.10.2
              19 verbose npm  v4.5.0
              20 error file sh
              21 error code ELIFECYCLE
              22 error errno ENOENT
              23 error syscall spawn
              24 error magicmirror@2.1.1 start: `sh run-start.sh`
              24 error spawn ENOENT
              25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
              25 error Make sure you have the latest version of node.js and npm installed.
              25 error If you do, this is most likely a problem with the magicmirror package,
              25 error not with npm itself.
              25 error Tell the author that this fails on your system:
              25 error     sh run-start.sh
              25 error You can get information on how to open an issue for this project with:
              25 error     npm bugs magicmirror
              25 error Or if that isn't available, you can get their info via:
              25 error     npm owner ls magicmirror
              25 error There is likely additional logging output above.
              26 verbose exit [ 1, true ]
              • NomisN
                Nomis
                https://forum.magicmirror.builders/topic/2460/magicmirror-fails-to-install-during-electron-installation
                loading…
                  DeanoAus
                  • /home/pi/MagicMirror/vendors npm install (This installed some missing stuff that seems to have not installed)
                  • /home/pi/MagicMirror/ npm install (This failed, but showed that electron was missing. Only failed due to permission)
                  • /home/pi/MagicMirror/ sudo npm install (This died with error ECONNRESET, so tried again)
                    DeanoAus @Nomis
                    @Nomis said in Electron NPM Error:
                    Those steps didn’t help.
                    NomisN 1 Reply Last reply Reply Quote 0
                    • NomisN
                      Nomis @DeanoAus
                      @DeanoAus
                      Sorry to hear that.
                      For me it worked with those dependencies fixed.
                      pi@raspberrypi:~$ npm -v ; node -v
                      4.1.2
                      v7.7.1
                      pi@raspberrypi:~$ cd MagicMirror/
                      pi@raspberrypi:~/MagicMirror$ cd node_modules/
                      pi@raspberrypi:~/MagicMirror/node_modules$ npm install electron
                      > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
                      > node install.js
                      magicmirror@2.1.1 /home/pi/MagicMirror
                      └── electron@1.6.6
                      Here the thread I’ve been looking last night: https://github.com/electron/electron/issues/9324
                      User: johannesjo made a fork: https://github.com/johannesjo/electron-prebuilt
                      But what I did was to downgrade the extract-zip:
                      pi@raspberrypi:~/MagicMirror/node_modules$ npm uninstall extract-zip
                      pi@raspberrypi:~/MagicMirror/node_modules$ npm install extract-zip@1.6.0
                      As a result of all this:
                      pi@raspberrypi:~/MagicMirror$ npm install
                      > magicmirror@2.1.1 install /home/pi/MagicMirror
                      > cd vendor && npm install
                      magicmirror-vendors@ /home/pi/MagicMirror/vendor
                      ├── font-awesome@4.7.0
                      ├── moment@2.18.1
                      ├── moment-timezone@0.5.13
                      └── weathericons@2.1.0
                      > magicmirror@2.1.1 postinstall /home/pi/MagicMirror
                      > sh installers/postinstall/postinstall.sh
                      MagicMirror installation successful!
                      Hope it helps
                      loading…
                        DeanoAus
                        now it’s just hanging at the install of electron. Been there for 5 minutes now :(
                        pi@Pi:~/MagicMirror $ cd node_modules/
                        pi@Pi:~/MagicMirror/node_modules $ sudo npm uninstall extract-zip
                        - ms@0.7.1 node_modules/extract-zip/node_modules/ms
                        - debug@2.2.0 node_modules/extract-zip/node_modules/debug
                        - pend@1.2.0 node_modules/pend
                        - fd-slicer@1.0.1 node_modules/fd-slicer
                        - yauzl@2.4.1 node_modules/yauzl
                        - extract-zip@1.6.4 node_modules/extract-zip
                        npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
                        npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                        pi@Pi:~/MagicMirror/node_modules $ sudo npm install extract-zip@1.6.0
                        └─┬ spectron@3.6.2
                          └─┬ electron-chromedriver@1.6.0
                            └─┬ extract-zip@1.6.0
                              ├─┬ concat-stream@1.5.0
                              │ └─┬ readable-stream@2.0.6
                              │   └── isarray@1.0.0
                              ├── debug@0.7.4
                              └─┬ yauzl@2.4.1
                                └─┬ fd-slicer@1.0.1
                                  └── pend@1.2.0
                        pi@Pi:~/MagicMirror/node_modules $ sudo npm install electron
                        > node install.js
                          DeanoAus
                          Soon as I wrote that…
                          > node install.js
                          └── electron@1.6.6
                            DeanoAus
                            pi@Pi:~/MagicMirror $ sudo npm install
                            npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/pi/MagicMirror
                            npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/pi/MagicMirror
                            • NomisN
                              Nomis
                              I ran into some trouble myself after installing the MMM-PIR-Sensor (the whole MM is not starting :D )
                              Mental Note: Remember to BackUp stable builds!
                              I don’t see the need of using sudo for npm install.
                              I’ve tried to replicate your error(took a while to undo the fixes):
                              npm list
                              npm ERR! extraneous: gulp-stylelint@3.9.0 /home/pi/MagicMirror/node_modules/gulp-stylelint
                              npm ERR! extraneous: stylelint@7.8.0 /home/pi/MagicMirror/node_modules/stylelint
                              npm purge
                              npm rebuild
                              got this: coffee-script@1.10.0 should be installed with -g // npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                              cd /MagicMirror/node_modules/
                              npm install  coffee-script@1.10.0 -g
                              npm install jsonlint@1.6.2 -g
                              npm install stylelint
                              npm install colorguard@1.2.0 -g
                              npm list (again yes)
                              you will get an error: npm ERR! extraneous: stylelint@7.10.1 /home/pi/MagicMirror/node_modules/stylelint because we instaleld manually.
                              Give it a try and let us know.
                              loading…
                                DeanoAus
                                Holy crap, that worked. I’m back in business!
                                1000 camels to you, good sir!
                                NomisN 1 Reply Last reply Reply Quote 1
                                • NomisN
                                  Nomis @DeanoAus
                                  @DeanoAus
                                  You are welcome and glad it works!
                                  loading…
                                  • F
                                    froinds
                                    They fixed the issue with extract-zip. Thanks.
