    Electron NPM Error
    28 Posts 7 Posters 25.8k Views 7 Watching
    • cowboysdudeC Offline
      cowboysdude Module Developer @DeanoAus
      @DeanoAus try the manual install. It seems to run smoother.
        DeanoAus
        I just tried
        npm install npm@latest -g
        npm install -g grunt
        npm install -g electron
        and when installing electron I get
        pi@Pi:~ $ sudo npm install -g electron
        /usr/bin/electron -> /usr/lib/node_modules/electron/cli.js
        > electron@1.6.6 postinstall /usr/lib/node_modules/electron
        > node install.js
        /usr/lib/node_modules/electron/install.js:47
          throw err
        Error: ENOENT: no such file or directory, lstat '/usr/lib/node_modules/electron/dist/resources'
            at Error (native)
        npm ERR! code ELIFECYCLE
        npm ERR! errno 1
        npm ERR! electron@1.6.6 postinstall: `node install.js`
        npm ERR! Exit status 1
        npm ERR!
        npm ERR! Failed at the electron@1.6.6 postinstall script 'node install.js'.
        npm ERR! If you do, this is most likely a problem with the electron package,
        npm ERR! not with npm itself.
        npm ERR!     node install.js
        npm ERR!     npm bugs electron
        npm ERR! Or if that isn't available, you can get their info via:
        npm ERR!     npm owner ls electron
        npm ERR!     /root/.npm/_logs/2017-05-01T02_57_00_518Z-debug.log
          Delete MM and re-download it.
          Install manually.
          Manual Installation
          • Download and install the latest Node.js version.
          • Clone the repository and check out the master branch: git clone https://github.com/MichMich/MagicMirror
          • Enter the repository: cd ~/MagicMirror
          • Install and run the app: npm install && npm start
          • Important: npm start does not work via SSH, use DISPLAY=:0 nohup npm start & instead. This starts the mirror on the remote display.
          Note: if you want to debug on Raspberry Pi you can use npm start dev which will start the MagicMirror app with Dev Tools enabled.
            DeanoAus @cowboysdude
            @cowboysdude said in Electron NPM Error:
            Ok, trying now.
              DeanoAus
              sigh Failed.
              pi@Pi:~ $ sudo apt-get install nodejs
              Reading package lists... Done
              Building dependency tree
              nodejs is already the newest version.
                libc-ares2 libv8-3.14.5
              Use 'apt-get autoremove' to remove them.
              pi@Pi:~ $ git clone https://github.com/MichMich/MagicMirror
              Cloning into 'MagicMirror'...
              remote: Counting objects: 7394, done.
              remote: Total 7394 (delta 0), reused 0 (delta 0), pack-reused 7394
              Receiving objects: 100% (7394/7394), 11.00 MiB | 492.00 KiB/s, done.
              Resolving deltas: 100% (4086/4086), done.
              Checking connectivity... done.
              pi@Pi:~ $ cd MagicMirror/
              pi@Pi:~/MagicMirror $ sudo npm install && npm start
              npm WARN prefer global coffee-script@1.10.0 should be installed with -g
              npm WARN prefer global jsonlint@1.6.2 should be installed with -g
              > electron-chromedriver@1.6.0 install /home/pi/MagicMirror/node_modules/electron-chromedriver
              > node ./download-chromedriver.js
              > electron@1.6.6 postinstall /home/pi/MagicMirror/node_modules/electron
              > node install.js
              /home/pi/MagicMirror/node_modules/electron/install.js:47
                throw err
              Error: ENOENT: no such file or directory, lstat '/home/pi/MagicMirror/node_modules/electron/dist/resources'
                  at Error (native)
              npm WARN grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
              npm WARN stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
              npm ERR! errno 1
              npm ERR!
              npm ERR!     /root/.npm/_logs/2017-05-01T03_24_28_075Z-debug.log
                @DeanoAus said in Electron NPM Error:
                Open this file
                See what it’s telling you…
                I really do have to go to bed … have to get up early but don’t give up…
                  DeanoAus
                  73493 silly postinstall electron@1.6.6
                  73494 info lifecycle electron@1.6.6~postinstall: electron@1.6.6
                  73495 verbose lifecycle electron@1.6.6~postinstall: unsafe-perm in lifecycle false
                  73496 verbose lifecycle electron@1.6.6~postinstall: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/electron/node_modules/.bin:/home/pi/MagicMirror/node_modul$
                  73497 verbose lifecycle electron@1.6.6~postinstall: CWD: /home/pi/MagicMirror/node_modules/electron
                  73498 silly lifecycle electron@1.6.6~postinstall: Args: [ '-c', 'node install.js' ]
                  73499 silly lifecycle electron@1.6.6~postinstall: Returned: code: 1  signal: null
                  73500 info lifecycle electron@1.6.6~postinstall: Failed to exec postinstall script
                  73501 verbose unlock done using /root/.npm/_locks/staging-f4a655787a5bf4d3.lock for /home/pi/MagicMirror/node_modules/.staging
                  73502 silly rollbackFailedOptional Starting
                  73503 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73504 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                  73505 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73506 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                  73507 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73508 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                  73509 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73510 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                  73511 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73512 verbose gentlyRm don't care about contents; nuking /home/pi/MagicMirror/node_modules/electron
                  73513 silly gentlyRm /home/pi/MagicMirror/node_modules/electron is being purged from base /home/pi/MagicMirror
                  73527 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73528 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73529 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73530 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73531 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73532 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73533 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73534 silly vacuum-fs quitting because other entries in /home/pi/MagicMirror/node_modules
                  73535 silly rollbackFailedOptional Finishing
                  73536 silly runTopLevelLifecycles Finishing
                  73537 silly install printInstalled
                  73538 warn grunt-stylelint@0.8.0 requires a peer of stylelint@^7.8.0 but none was installed.
                  73539 warn stylelint-config-standard@16.0.0 requires a peer of stylelint@^7.8.0 but none was installed.
                  73540 verbose stack Error: electron@1.6.6 postinstall: `node install.js`
                  73540 verbose stack Exit status 1
                  73540 verbose stack     at EventEmitter. (/usr/lib/node_modules/npm/lib/utils/lifecycle.js:279:16)
                  73540 verbose stack     at emitTwo (events.js:106:13)
                  73540 verbose stack     at EventEmitter.emit (events.js:191:7)
                  73540 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:40:14)
                  73540 verbose stack     at ChildProcess.emit (events.js:191:7)
                  73540 verbose stack     at maybeClose (internal/child_process.js:886:16)
                  73540 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                  73541 verbose pkgid electron@1.6.6
                  73542 verbose cwd /home/pi/MagicMirror
                  73543 verbose Linux 4.9.24-v7+
                  73544 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "install"
                  73545 verbose node v6.10.2
                  73546 verbose npm  v4.5.0
                  73547 error code ELIFECYCLE
                  73548 error errno 1
                  73549 error electron@1.6.6 postinstall: `node install.js`
                  73549 error Exit status 1
                  73550 error Failed at the electron@1.6.6 postinstall script 'node install.js'.
                  73550 error Make sure you have the latest version of node.js and npm installed.
                  73550 error If you do, this is most likely a problem with the electron package,
                  73550 error not with npm itself.
                    mitchscobell
                    I am having the same problem. Wiped the pi and reflashed the image from scratch. Spent a few hours myself tonight trying various things to fix it without getting anywhere. Same exact errors as pasted above.
                    • W Offline
                      WinterRain
                      I’m getting the same problem. Started from scratch a few times but no luck. Finally managed to have it installed to the point where I could run using node serveronly then running on a browser. Also had to use ~/MagicMirror/vendor npm install as this seem to have been skipped in the auto installation when it hit the electron error.
                        DeanoAus
                        Is there any way we can get a dev to look at this?
                          DeanoAus
                          I installed npm in Vendors. Now my error log is significantly less, but still dies.
                          1 verbose cli [ '/usr/bin/nodejs', '/usr/bin/npm', 'start' ]
                          2 info using npm@4.5.0
                          3 info using node@v6.10.2
                          5 info lifecycle magicmirror@2.1.1~prestart: magicmirror@2.1.1
                          6 silly lifecycle magicmirror@2.1.1~prestart: no script for prestart, continuing
                          7 info lifecycle magicmirror@2.1.1~start: magicmirror@2.1.1
                          8 verbose lifecycle magicmirror@2.1.1~start: unsafe-perm in lifecycle true
                          9 verbose lifecycle magicmirror@2.1.1~start: PATH: /usr/lib/node_modules/npm/bin/node-gyp-bin:/home/pi/MagicMirror/node_modules/.bin:/usr/local/sbin$
                          10 verbose lifecycle magicmirror@2.1.1~start: CWD: /home/pi/MagicMirror
                          11 silly lifecycle magicmirror@2.1.1~start: Args: [ '-c', 'sh run-start.sh' ]
                          12 info lifecycle magicmirror@2.1.1~start: Failed to exec start script
                          13 verbose stack Error: magicmirror@2.1.1 start: `sh run-start.sh`
                          13 verbose stack spawn ENOENT
                          13 verbose stack     at ChildProcess. (/usr/lib/node_modules/npm/lib/utils/spawn.js:33:16)
                          13 verbose stack     at emitTwo (events.js:106:13)
                          13 verbose stack     at ChildProcess.emit (events.js:191:7)
                          13 verbose stack     at maybeClose (internal/child_process.js:886:16)
                          13 verbose stack     at Process.ChildProcess._handle.onexit (internal/child_process.js:226:5)
                          14 verbose pkgid magicmirror@2.1.1
                          15 verbose cwd /home/pi/MagicMirror
                          16 verbose Linux 4.9.24-v7+
                          17 verbose argv "/usr/bin/nodejs" "/usr/bin/npm" "start"
                          18 verbose node v6.10.2
                          19 verbose npm  v4.5.0
                          20 error file sh
                          21 error code ELIFECYCLE
                          22 error errno ENOENT
                          23 error syscall spawn
                          24 error magicmirror@2.1.1 start: `sh run-start.sh`
                          24 error spawn ENOENT
                          25 error Failed at the magicmirror@2.1.1 start script 'sh run-start.sh'.
                          25 error Make sure you have the latest version of node.js and npm installed.
                          25 error If you do, this is most likely a problem with the magicmirror package,
                          25 error not with npm itself.
                          25 error Tell the author that this fails on your system:
                          25 error     sh run-start.sh
                          25 error You can get information on how to open an issue for this project with:
                          25 error     npm bugs magicmirror
                          25 error Or if that isn't available, you can get their info via:
                          25 error     npm owner ls magicmirror
                          25 error There is likely additional logging output above.
                          26 verbose exit [ 1, true ]
                          • NomisN Offline
                            Nomis
                            https://forum.magicmirror.builders/topic/2460/magicmirror-fails-to-install-during-electron-installation
                            loading…
                              DeanoAus
                              • /home/pi/MagicMirror/vendors npm install (This installed some missing stuff that seems to have not installed)
                              • /home/pi/MagicMirror/ npm install (This failed, but showed that electron was missing. Only failed due to permission)
                              • /home/pi/MagicMirror/ sudo npm install (This died with error ECONNRESET, so tried again)
                                DeanoAus @Nomis
                                @Nomis said in Electron NPM Error:
                                Those steps didn’t help.
                                NomisN 1 Reply Last reply Reply Quote 0
                                • NomisN Offline
                                  Nomis @DeanoAus
                                  @DeanoAus
                                  Sorry to hear that.
                                  For me it worked with those dependencies fixed.
                                  pi@raspberrypi:~$ npm -v ; node -v
                                  4.1.2
                                  v7.7.1
                                  pi@raspberrypi:~$ cd MagicMirror/
                                  pi@raspberrypi:~/MagicMirror$ cd node_modules/
                                  pi@raspberrypi:~/MagicMirror/node_modules$ npm install electron
                                  > node install.js
                                  magicmirror@2.1.1 /home/pi/MagicMirror
                                  └── electron@1.6.6
                                  Here the thread I’ve been looking last night: https://github.com/electron/electron/issues/9324
                                  User: johannesjo made a fork: https://github.com/johannesjo/electron-prebuilt
                                  But what I did was to downgrade the extract-zip:
                                  pi@raspberrypi:~/MagicMirror/node_modules$ npm uninstall extract-zip
                                  pi@raspberrypi:~/MagicMirror/node_modules$ npm install extract-zip@1.6.0
                                  As a result of all this:
                                  pi@raspberrypi:~/MagicMirror$ npm install
                                  > magicmirror@2.1.1 install /home/pi/MagicMirror
                                  > cd vendor && npm install
                                  magicmirror-vendors@ /home/pi/MagicMirror/vendor
                                  ├── font-awesome@4.7.0
                                  ├── moment@2.18.1
                                  ├── moment-timezone@0.5.13
                                  └── weathericons@2.1.0
                                  > magicmirror@2.1.1 postinstall /home/pi/MagicMirror
                                  > sh installers/postinstall/postinstall.sh
                                  MagicMirror installation successful!
                                  Hope it helps
                                  loading…
                                    DeanoAus
                                    now it’s just hanging at the install of electron. Been there for 5 minutes now :(
                                    pi@Pi:~/MagicMirror $ cd node_modules/
                                    pi@Pi:~/MagicMirror/node_modules $ sudo npm uninstall extract-zip
                                    - ms@0.7.1 node_modules/extract-zip/node_modules/ms
                                    - debug@2.2.0 node_modules/extract-zip/node_modules/debug
                                    - pend@1.2.0 node_modules/pend
                                    - fd-slicer@1.0.1 node_modules/fd-slicer
                                    - yauzl@2.4.1 node_modules/yauzl
                                    - extract-zip@1.6.4 node_modules/extract-zip
                                    pi@Pi:~/MagicMirror/node_modules $ sudo npm install extract-zip@1.6.0
                                    └─┬ spectron@3.6.2
                                      └─┬ electron-chromedriver@1.6.0
                                        └─┬ extract-zip@1.6.0
                                          ├─┬ concat-stream@1.5.0
                                          │ └─┬ readable-stream@2.0.6
                                          │   └── isarray@1.0.0
                                          ├── debug@0.7.4
                                          └─┬ yauzl@2.4.1
                                            └─┬ fd-slicer@1.0.1
                                              └── pend@1.2.0
                                    pi@Pi:~/MagicMirror/node_modules $ sudo npm install electron
                                    > node install.js
                                      DeanoAus
                                      Soon as I wrote that…
                                      > node install.js
                                      └── electron@1.6.6
                                        DeanoAus
                                        npm WARN lifecycle magicmirror@2.1.1~install: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 cd vendor && npm install /home/pi/MagicMirror
                                        npm WARN lifecycle magicmirror@2.1.1~postinstall: cannot run in wd %s %s (wd=%s) magicmirror@2.1.1 sh installers/postinstall/postinstall.sh /home/pi/MagicMirror
                                        • NomisN Offline
                                          Nomis
                                          I ran into some trouble myself after installing the MMM-PIR-Sensor (the whole MM is not starting :D )
                                          Mental Note: Remember to BackUp stable builds!
                                          I don’t see the need of using sudo for npm install.
                                          I’ve tried to replicate your error(took a while to undo the fixes):
                                          npm list
                                          npm ERR! extraneous: gulp-stylelint@3.9.0 /home/pi/MagicMirror/node_modules/gulp-stylelint
                                          npm ERR! extraneous: stylelint@7.8.0 /home/pi/MagicMirror/node_modules/stylelint
                                          npm purge
                                          npm rebuild
                                          got this: coffee-script@1.10.0 should be installed with -g // npm WARN prefer global jsonlint@1.6.2 should be installed with -g
                                          cd /MagicMirror/node_modules/
                                          npm install  coffee-script@1.10.0 -g
                                          npm install jsonlint@1.6.2 -g
                                          npm install stylelint
                                          npm install colorguard@1.2.0 -g
                                          npm list (again yes)
                                          you will get an error: npm ERR! extraneous: stylelint@7.10.1 /home/pi/MagicMirror/node_modules/stylelint because we instaleld manually.
                                          Give it a try and let us know.
                                          loading…
                                            DeanoAus
                                            Holy crap, that worked. I’m back in business!
                                            1000 camels to you, good sir!
                                            NomisN 1 Reply Last reply Reply Quote 1
