    (2.1.1) Options of Clock broadcast event
    Scheduled Pinned Locked Moved Upcoming Features
    5 Posts 3 Posters 4.3k Views 2 Watching
    • slametpsS Offline
      slametps
      I use 3 time-based modules (Scheduler, AlarmClock, PrayerTime). Each module implement internal timer to check current time if there is a trigger an event. IMO, it will more efficient if the module use a broadcast event from Clock module (every minute and/or every hour, each configured through config.js) to trigger particular event in the user module. The Clock broadcast event will contain date (MM/DD/YYYY) and time (hh : mm : ss) minimally.
      @MichMich : What do you think?
      regards,
      Slamet PS
      • strawberry 3.141S Offline
        strawberry 3.141 Project Sponsor Module Developer @slametps
        @slametps This would mean that every user has to use the clock module. It is not like the alert module which doesn’t have an ui. The event would trigger every module also the hidden ones. As some modules would need broadcasts every second the performance would be worse.
        slametpsS 1 Reply Last reply Reply Quote 0
        • slametpsS Offline
          slametps @strawberry 3.141
          @strawberry-3.141 : so, implement broadcast event in Clock is not efficient rather than module internal timer? I mean, it is an on/off option. User can activate clock broadcast event if required.
          regards,
          Slamet PS
            broberg Project Sponsor @slametps
            If you need re-occuring events isnt the calendar a better option? I do believe the calendar already has the option to send notifcations on calendar events.
            • slametpsS Offline
              slametps @broberg
              @broberg : the requirement is not like that. The original idea is module internal timer with 1 second interval for example, can be replaced with event from the clock. The module no longer required to implement the timer itself.
              regards,
              Slamet PS
