    MMM-MyCommute
    286 Posts 80 Posters 653.2k Views 77 Watching
      binia
      I think i have a problem with the API.
      Idk whats wrong.
        Bob
        What is the error code for it ? If it’s 403, then check your login credentials.
        Also what does “pm2 log” show from the command prompt ? That can give some indication of the issue.
          binia
          I got the 403 error. I need to logon on the Pi? for the Module ?
          I dont understand that i got error 403 and 200 on same time.
          First way is error 403
          Second way is 200 and its show me the Data.
            binia
            @bob said in MMM-MyCommute:
            Okay it say me the daily request have exceeded. but its only 1 request for a day?
            i need a activate billing account?
              mcgnai
              hi … I have a premium key made up of Client ID: and Crypto Key:
              can I use it for this module? if so how should I insert them in the config? thank you
              • K Offline
                keithsizer
                Hi all, I hope you can help me? I can’t get this to work, no matter what I try. I’ve read everything I’ve found about this module, and tried everything, but nothing works. At the moment, I have copied and pasted the example entry, only adding the api key. Everything loads up with errors next to them. What am I doing wrong? On the google console, which api do I need to enable (currently, I’ve enabled everything for google maps)
                  soundarchitect @keithsizer
                  @keithsizer Hi, you should just activate the “Directions API” on Google console. Best, L.
                    Akutik
                    Is it right that you have to pay for Google Directions API for now? So if I dont pay for that I only have one request for each day? Because my log says my daily request have exceeded:/
                      Smotx
                      a question about,
                      sorry if i’m not clear, my english is bad.
                      now that the APIs are no longer free, when the functions ‘start time / end time’ are activated and the module is not displayed on MagicMirror, does it make requests to google?
                      Ex. : If i set endTime: '09:00', , module continues requests after ?
                      C J 2 Replies Last reply Reply Quote 0
                      • C Offline
                        canadrian @Smotx
                        This post is deleted!
                        • 17
                        • 18
                        • 19
                        • 20
                        • 21
                        • 28
                        • 29
                        • 19 / 29
