MMM-Voice libpocketsphinx.so.3: cannot open shared object file: No such file or directory[update]
Hi everyone,
I have bought a USB microphone and I have plugged it into the raspberry pi. After I have installed the MMM-Voice as it is described on the website. Once I start the Magic mirror, on the bottom part I have the message “Ready, choose a mode”. However, I have tried to say the keyword + the mode and I have not got any change.
I was able to fix the problem with the library adding the path in /etc/ld.so.conf and updating the ldconf. Now when I restart the model with debug:true. I do not have any error.log, I have just a huge text from pocketsphinx. At end the you can read as “continuous.c(275): Ready…”. But, the module still does not recognize my commands. I have checked the microphone and it is working without problems.
Thanks in advance for all your help.
Hey there,
I have excactly the same problem. My mic works as well.
Hanauta any solution yet? Which path did you enter in /etc/ld.so.conf ?
My file in /etc/ld.so.conf contents this right now:
# libc default configuration /usr/local/libThanks in advance
Kind Regards
