    mm-music-player throws an error ?
    1 Posts 1 Posters 1.2k Views 1 Watching
      seifanov
      Hello everyone !
      i am actually trying to build my first magic mirror, i tried to install mm-music-player module with no success, this is my config for the module:
      		module: 'mm-music-player',
      		position: 'bottom_left',
      			startingVolume: 20,
      			fadeDuriation: 2000
      every time I launch it it throws this error
      Initializing mm-music-player module helper ...
      WARNING! Could not load config file. Starting with default configuration. Error found: TypeError: m.loaded is not a function
      Loading module helpers ...
      No helper found for module: logoCol.
      Module helper loaded: MMM-Remote-Control
      App threw an error during load
          at loadModule (/home/seif/Desktop/MagicMirror/js/app.js:144:6)
          at loadNextModule (/home/seif/Desktop/MagicMirror/js/app.js:161:5)
          at /home/seif/Desktop/MagicMirror/js/app.js:163:6
          at Class.loaded (/home/seif/Desktop/MagicMirror/modules/node_modules/node_helper/index.js:19:3)
          at loadModule (/home/seif/Desktop/MagicMirror/js/app.js:146:4)
      Launching application.
      what is the problem ? i tried this in my ubuntu pc and on a raspberry pi2 with no success …
