    Exchange calendar not showing up
    6 Posts 2 Posters 3.2k Views 2 Watching
    • P Offline
      pieterbeulens
      Hi guys. I’ve looked through all the other posts saying te calendar is not showing up, but I seem to be having a different problem. I use two different Exchange calendars from the same Exchange server. One is working, the other one isn’t. When I use npm start dev, I see the following error:
      TypeError: curr.exdates[i].toISOString is not a function
          at Object.ical.objectHandlers.END (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:44:44)
          at Object.handleObject (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:267:41)
          at Object.parseICS (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/ical.js:308:20)
          at Request._callback (/home/pi/MagicMirror/modules/default/calendar/vendor/ical.js/node-ical.js:11:24)
          at Request.self.callback (/home/pi/MagicMirror/node_modules/request/request.js:188:22)
          at emitTwo (events.js:106:13)
          at Request.emit (events.js:191:7)
          at Request. (/home/pi/MagicMirror/node_modules/request/request.js:1171:10)
          at emitOne (events.js:96:13)
          at Request.emit (events.js:188:7)
      What could be going wrong here?
      • bheplerB Offline
        bhepler Module Developer @pieterbeulens
        @pieterbeulens Can you check each calendar to see if they have different types of events in them? There may be an issue between all day events and normal start/end events. Or possibly events that span multiple days.
        My initial guess is that an event that spans multiple days does not have time associated with it. That may be throwing the module off.
        • P Offline
          pieterbeulens
          I think that might just be the case! This calendar used to work though on the previous mm version. Is there something I could do to fix this?
          • P Offline
            pieterbeulens @bhepler
            @bhepler I’m afraid I don’t know much about coding, so still hoping there might be something that can be done about this problem.
            • bheplerB Offline
              @pieterbeulens I’m kind of swamped at the moment, so I can’t look at it for a couple weeks. My suggestion for right now is to create a test calendar and populate it with discreet events. Nothing that overlaps days, nothing that is an all-day event. See if you can’t connect and display it normally.
              Once you’ve confirmed that it works, add a multi-day event and see if it breaks. Let’s isolate the exact problem and then we have a test case we can use for fixes.
              • P Offline
                pieterbeulens
                So sorry for the very late reply. I didn’t have time to work on my project. But today I picked it up again and also found https://github.com/MichMich/MagicMirror/issues/839. When I updated the ical.js and node-ical.js in this thread, my calendar started showing up. So I’m happy and almost finished my MM. Version 0.1, that is…
