Edit view of MMM-Remote-Control doesn't work with cloned MMM-bitcoin module
5 Posts 4 Posters 2.5k Views 4 Watching
    sko22
    Helo, I have cloned the valmassoi/MMM-bitcoin module:
    https://github.com/valmassoi/MMM-bitcoin
    and changed url to get the ethereum currency for my magic mirror but when i active it the Jopyth/MMM-Remote-Control:
    https://github.com/Jopyth/MMM-Remote-Control
    the “Edit view” function doesn’t work anymore but i have only thi message " No module loaded."
    Can you help me to work it again?
    • N Offline
      ndom91
      I had the same prbolem, had to disabled MMM-bitcoin/ MMM-ethereum. Why they’re incompaitible I wasn’t able to find out, unfortunately, but it works again if you disable the crypto tickers :)
      • E Offline
        E3V3A
        You should post an issue to the github.
        But, that said, I believe (I’ve never used this module) it keep track of changes to main MM config.js file, so if you change it, without restarting MM, this module will get confused. (make sure to use pm2 kill to avoid cached files.)
        "Everything I do (here) is for free – altruism is the way!"
        MMM-FlightsAbove, MMM-Tabulator, MMM-Assistant (co-maintainer)
        • N Offline
          ndom91
          I did mentioned it on the github page of the ethereum module. The crypto tickers aren’t really that important to me. I’ve moved on haha Thanks anyway!
          • G Offline
            Gabev
            You can find any information about bitcoin here: https://bitcoinbestbuy.com. There is a detailed guide for beginners, in which countries and what cryptocurrency. How to buy in USA and so on. Very interesting and cool articles and more!
