    socket.io missing - manual installation
    3 Posts 2 Posters 2.6k Views 2 Watching
    • L Offline
      LOCOSP
      Hi, I’ve tried to install MM on my Slackware Server, and after clone and npm install & npm start but socket.io is missing and script is looking for it outside of project directoryscreen shot
      • ? Offline
        [[global:former-user]]
        had the same error…
        1. download sails.io.js
        $ cd /var/www/html/MagicMirror/js
        $ sudo wget https://raw.githubusercontent.com/balderdashy/sails.io.js/master/dist/sails.io.js
        1. edit index.html
        $ sudo nano index.html
        Change line 30 from:
        <script type="text/javascript" src="/socket.io/socket.io.js"></script>
        to:
        <script type="text/javascript" src="/js/socket.js"></script>
        Add this line right before line 30:
        <script type="text/javascript" src="js/sails.io.js"</script>
        Worked for me, cheers!
        • L Offline
          LOCOSP
          Yes, thank You very much :) it is working…
          But calendar module and rss feed module is loading and loading, config file is ok because “server only” is fine, any ideas ?
