    Analog + Digital Clock module
    38 Posts 5 Posters 49.0k Views 5 Watching
    • KirAsh4K Offline
      KirAsh4 Moderator
      a) what comes before ALPHA, or BETA? whatever it is, that’s the state of the code
      b) at the moment it’s a separate module, will see about merging it with the current (default) clock
      • K Offline
        Kevin
        Cool, looking good.
        Hehe, right now it’s purely cosmetic with both analog and digital. Looking forward to the beta, delta, omega versions :)
        • KirAsh4K Offline
          KirAsh4 Moderator
          Myah, found a few bugs in both the JS and CSS, which are now fixed. (Also found a conflict with same name CSS files across different modules.) Tomorrow I’ll start working on incorporating it with the default one, and see how to make it work so both can be displayed, or one of them while allowing for everything else to reflow gracefully. Adding some config features at the moment … which means I get to play a bit:
          • K Offline
            Kevin
            Fantastic! Looks great. Would be nice if you can ajust the placement of the analog dail, if you manage to implement it to the original clock script.
            • KirAsh4K Offline
              KirAsh4 Moderator
              Adjust placement?
              • K Offline
                Kevin
                ex. right of, left of, over or under the digital time…
                • KirAsh4K Offline
                  KirAsh4 Moderator
                  Oh that … yeah that will need to be worked out once merged with the other. The current thought process is:
                  displayType: "analog" || "digital" || "both",
                  analogPlacement: "top" || "right" || " bottom" || "left",
                  analogFace: "face-001" || "face-N",
                  There’s likely to be (more) changes/additions as well.
                  • KirAsh4K Offline
                    KirAsh4 Moderator
                    Digital or Analog
                    Both: Analog “top” or “bottom”
                    Both: Analog “left” or “right”
                    Other options include:
                    • ability to change the face of the analog clock
                    • ability to change the size of the analog clock
                    Does that about cover it @Kevin? :)
                    • KirAsh4K Offline
                      KirAsh4 Moderator
                      By the way, there are a few more options being added, specific to the analog clock. While I like my “second” hand to be red, the default will be gray, but I’ll make a config option so people can change its color to something else.
                      I’m also going to have it take into account the 'config.displaySeconds' options.
                      • KirAsh4K Offline
                        KirAsh4 Moderator
                        Also, @MichMich, if you have other requests or comments before I create a PR, now’s the time.
                        • 3 / 4
