    How to update.
    35 Posts 21 Posters 94.7k Views 20 Watching
      dam4 @Snille
      @Snille
      I am new to Linex and I have copied your script exactly and I get the following error.
      -bash: update.sh: command not found
      I called the script update.sh and I was going to use it in a cron job after I tested it to make sure it worked. Can you tell me what I might have done wrong. Thank you in advance for your help.
      • I Offline
        izanbard @dam4
        @dam4 It is likely that two things are wrong.
        First the script needs to be executable so please run:
        $ chmod u+x update.sh
        this will add execute permissions for the file owner to the file. Have a look at man chmod for more detail.
        The next thing is to make sure that Linux knows where to look for it. This can be quite a complicated subject involving descriptions of the $PATH environment variable and all sorts. But the easy way to do it is to add a relative or absolute path to the start of the command. So from the command prompt in the folder where the script exists try:
        $ ./update.sh
        where the . means “this folder”. For the cron tab through you might want to use the full path something like:
        0 2 * * * /full/path/to/file/update.sh
        Hope at least some of that is meaningful for you.
        D 1 Reply Last reply Reply Quote 2
          dam4 @izanbard
          @izanbard
          Thank you. I did the chmod to make it executable but using the ./update.sh worked. Thank you again for your help.
          • L Offline
            LucrativeRook62
            This post is deleted!
              Arjan Project Sponsor
              • 4 / 4
