    How to update.
    35 Posts 21 Posters 96.3k Views 20 Watching
    • UnboredU Offline
      Unbored @izanbard
      This post is deleted!
      • UnboredU Offline
        Unbored @izanbard
        @izanbard Thank you.
         #!/usr/bin/env bash
        cd /home/pi/MagicMirror
        echo "######### CHECKING MAGIC MIRROR ##########"
        Has anyone else deployed this script?
        When I try to run it as a .py or .sh there is an error on line 6 stating invalid syntax at the end of the first echo row. Any suggestions on clearing this issue?
          Binog @Unbored
          @Unbored
          Delete the " and add straight ones again " (If You edited this file via an alternate editor on win/Mac then it might be a cursive "… try it, worked for me!
          • K Offline
            KX900
            hi
            i get this message:
            error: Your local changes to the following files would be overwritten by merge:
            	modules/default/calendar/calendar.js
            	modules/default/compliments/compliments.js
            	modules/default/newsfeed/newsfeed.js
            Please, commit your changes or stash them before you can merge.
            Aborting
            what should i do?
            • brobergB Offline
              broberg Project Sponsor @KX900
              @KX900 backup those files somewhere if you want to keep the changes you’ve made (you shouldn’t have made any changes in those files unless you really reaally had to) and then delete them and try to update again.
              • K Offline
                KX900 @broberg
                @broberg
                thank you.
                i had to do the changes because of “Umlaute”.
                  SpecialRob @akrishnan.j
                  @akrishnan.j
                  I was just searching for the same thing and had the same error message.
                  I renamed the offending file
                  ran the sudo git pull && nom install command
                  update worked fine without error and installed a new copy of offending file
                  copy the original file back if your edits were critical
                  • G Offline
                    gripworks
                    I have never had an issue updating until tonight. I got the following message back and am not sure how to proceed.
                    pi@magicmirror:~/MagicMirror $ git pull
                    *** Please tell me who you are.
                    Run
                      git config --global user.email "you@example.com"
                      git config --global user.name "Your Name"
                    to set your account's default identity.
                    Omit --global to set the identity only in this repository.
                    fatal: empty ident name (for ) not allowed
                    I’m sure it’s something stupid I don’t understand ,(not super knowledgeable about linux). I have tried entering various credentials in various ways but my lack of understanding the correct syntax seems to be my undoing.
                    Thanks in advance.
                    • SnilleS Offline
                      Snille Module Developer
                      @gripworks this usually happens when you have cloned the repository with ssh instead of https.
                      At least that’s what I have figured out works. :)
                      If you just do the suggested commands it’s all solved.
                      It’s github that wants to know who you are. :)
                      If you cant find it, make it and share it!
                      Modules: MMM-homeassistant-sensors, MMM-Modulebar, MMM-Profilepicture, MMM-Videoplayer
                      • G Offline
                        gripworks
                        Thank you, That worked. I appreciate the help.
                          dam4 @Snille
                          @Snille
                          I am new to Linex and I have copied your script exactly and I get the following error.
                          -bash: update.sh: command not found
                          I called the script update.sh and I was going to use it in a cron job after I tested it to make sure it worked. Can you tell me what I might have done wrong. Thank you in advance for your help.
                          • I Offline
                            izanbard @dam4
                            @dam4 It is likely that two things are wrong.
                            First the script needs to be executable so please run:
                            $ chmod u+x update.sh
                            this will add execute permissions for the file owner to the file. Have a look at man chmod for more detail.
                            The next thing is to make sure that Linux knows where to look for it. This can be quite a complicated subject involving descriptions of the $PATH environment variable and all sorts. But the easy way to do it is to add a relative or absolute path to the start of the command. So from the command prompt in the folder where the script exists try:
                            $ ./update.sh
                            where the . means “this folder”. For the cron tab through you might want to use the full path something like:
                            0 2 * * * /full/path/to/file/update.sh
                            Hope at least some of that is meaningful for you.
                            D 1 Reply Last reply Reply Quote 2
                              dam4 @izanbard
                              @izanbard
                              Thank you. I did the chmod to make it executable but using the ./update.sh worked. Thank you again for your help.
                              • L Offline
                                LucrativeRook62
                                  Arjan Project Sponsor
