    How to update.
    35 Posts 21 Posters 98.6k Views 20 Watching
      [[global:former-user]] @bhepler
      @bhepler said in How to update.:
      @wjdw87 The readme.md is also downloaded with the MirrorMirror code when you run the installation command. You’ll find it on your Pi at ~/MagicMirror/README.md.
      thanks
        Binog
        But is there a way (a sh-script) to update MM and all (!) of the installed (different) modules in a batch. I now do have to go through all the directories recursively. That takes lots of time and is quite annoying. Any idea?
        Thx Jimmy
        • I Offline
          izanbard
          I use this script, which comes with no guarantee:
           #!/usr/bin/env bash
          cd /home/pi/MagicMirror
          echo "######### CHECKING MAGIC MIRROR ##########"
          git fetch
          if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]
          then
              echo "######### UPGRADING MAGIC MIRROR #########"
              git pull
              npm install
          else
              echo "######## NO UPGRADE REQUIRED #########"
          fi
          echo ""
          cd modules
          for directory in *; do
              if [[ -d ${directory} && ${directory} != "node_modules" && ${directory} != "default" ]]; then
                  echo "######### CHECKING ${directory} ##########"
                  cd ${directory}
                  git fetch
                  if [ $(git rev-parse HEAD) != $(git rev-parse @{u}) ]; then
                      echo "######### UPGRADING ${directory} #########"
                      git pull
                      if [[ -e "package.json" && -f "package.json" ]]; then
                          npm install
                      fi
                  else
                  fi
                  echo ""
                  cd ..
              fi
          done
          SnilleS johnnyboyJ R UnboredU 6 Replies Last reply Reply Quote 4
          • SnilleS Offline
            Snille Module Developer @izanbard
            @izanbard Thank you for this! :)
              Binog
              Thank You, awesome !
              • johnnyboyJ Offline
                johnnyboy @izanbard
                • SnilleS Offline
                  @izanbard Hello, added a restart of the mirror (via pm2) if an npm install has been done and also added “–production” to the npm install command. Sometimes the module-developer have lot’s of extra stuff added in the package list just for developing. :)
                  I’m currently now running this script via CRON every night. :)
                  #!/usr/bin/env bash
                  updated=false
                  echo "Checking for MagicMirror updates."
                  git fetch
                  then
                      echo "Found, updating..."
                      git pull
                      npm install
                      updated=true
                      echo "Update done."
                  else
                      echo "No update needed."
                  fi
                  echo ""
                  cd modules
                          echo "Checking for ${directory} updates."
                          cd ${directory}
                          git fetch
                              echo "Found, updating ${directory}..."
                              git pull
                                  echo "package.joson changed for ${directory}, installing..."
                                  npm install --production
                                  updated=true
                                  echo "Update done."
                              fi
                          else
                          fi
                          echo ""
                          cd ..
                      fi
                  done
                  if $updated; then
                      echo "Restart of MM needed, restarting now."
                      pm2 restart mm
                  fi
                  echo "All done. :)"
                    RudyAcevedo @izanbard
                    @izanbard Thank you!!
                      batzyn
                      thank u!
                        akrishnan.j @batzyn
                        @batzyn
                        pi@akpi:~/MagicMirror $ sudo git pull && npm install
                        Updating 8010e62…5c41e24
                        error: Your local changes to the following files would be overwritten by merge:
                        css/main.css
                        Please, commit your changes or stash them before you can merge.
                        Aborting
                        Any ideas…
                        johnnyboyJ S 2 Replies Last reply Reply Quote 0
                          johnnyboy @akrishnan.j
                          • UnboredU Offline
                            Unbored @izanbard
                            • UnboredU Offline
                              Unbored @izanbard
                              @izanbard Thank you.
                               #!/usr/bin/env bash
                              Has anyone else deployed this script?
                              When I try to run it as a .py or .sh there is an error on line 6 stating invalid syntax at the end of the first echo row. Any suggestions on clearing this issue?
                                Binog @Unbored
                                @Unbored
                                Delete the " and add straight ones again " (If You edited this file via an alternate editor on win/Mac then it might be a cursive "… try it, worked for me!
                                • K Offline
                                  KX900
                                  hi
                                  i get this message:
                                  	modules/default/calendar/calendar.js
                                  	modules/default/compliments/compliments.js
                                  	modules/default/newsfeed/newsfeed.js
                                  Aborting
                                  what should i do?
                                    broberg Project Sponsor @KX900
                                    @KX900 backup those files somewhere if you want to keep the changes you’ve made (you shouldn’t have made any changes in those files unless you really reaally had to) and then delete them and try to update again.
                                    • K Offline
                                      KX900 @broberg
                                      @broberg
                                      thank you.
                                      i had to do the changes because of “Umlaute”.
                                        SpecialRob @akrishnan.j
                                        @akrishnan.j
                                        I was just searching for the same thing and had the same error message.
                                        I renamed the offending file
                                        ran the sudo git pull && nom install command
                                        update worked fine without error and installed a new copy of offending file
                                        copy the original file back if your edits were critical
                                        • G Offline
                                          gripworks
                                          I have never had an issue updating until tonight. I got the following message back and am not sure how to proceed.
                                          pi@magicmirror:~/MagicMirror $ git pull
                                          *** Please tell me who you are.
                                          Run
                                            git config --global user.email "you@example.com"
                                            git config --global user.name "Your Name"
                                          to set your account's default identity.
                                          Omit --global to set the identity only in this repository.
                                          fatal: empty ident name (for ) not allowed
                                          I’m sure it’s something stupid I don’t understand ,(not super knowledgeable about linux). I have tried entering various credentials in various ways but my lack of understanding the correct syntax seems to be my undoing.
                                          Thanks in advance.
                                          • SnilleS Offline
                                            @gripworks this usually happens when you have cloned the repository with ssh instead of https.
                                            At least that’s what I have figured out works. :)
                                            If you just do the suggested commands it’s all solved.
                                            It’s github that wants to know who you are. :)
