    start on reboot
    14 Posts 6 Posters 10.4k Views 5 Watching
    • B
      Bu52
      I would like to have npm start executed upon reboot. I’ve gone through every line of the install procedure (which is very good, BTW), but I have to manually open a terminal window from the gui and then cd HOME/MagicMirror and then npm start. This works fine. But how do I get it to do it automatically upon a reboot?
      • KirAsh4K
        KirAsh4 Moderator
        I didn’t get a chance to write that part yet, however it is (also) documented on the wiki:
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
        B 1 Reply Last reply
        • B
          Bu52 @KirAsh4
          @KirAsh4 Thank-you for adding to my knowledge again!!
          • KirAsh4K
            KirAsh4 Moderator
            Part of the reason for the auto starting is that occasionally, npm will die, and having the auto restart will take care of that as well.
            • B
              Bu52 @KirAsh4
              @KirAsh4 Well, it must be working well because it has been 12 hours and it is still going strong. However, I don’t know how many times pm2 had to restart it. Either way, my perception is that it is working fine. Thanks again.
              • KirAsh4K
                KirAsh4 Moderator
                Log into your rpi and execute 'pm2 list' to list all running pm2 tasks. If you have a bunch of them, then add the task name, like 'pm2 list <TASK NAME>'.
                If you want more info on a specific task, execute 'pm2 show <TASK NAME>'.
                You’ll get info screens like this:
                X 1 Reply Last reply
                • X
                  xbmcnut @KirAsh4
                  @KirAsh4 Thanks for the screenshots. I’m having trouble with mine starting after a reboot too and when I run pm2 list, it does not show a PID even though MM is working. Is that why it won’t start on reboot?
                  0_1489397924822_upload-5ea2ce1a-ac9b-46bf-b907-33133f2ff9ac
                  • X
                    xbmcnut
                    OK, did pm2 restart mm and now have a better result. Am I right to issue pm2 save after that?
                    0_1489398453521_upload-00e37575-c508-4665-b348-1be887be8cb0
                    • X
                      xbmcnut
                      OK, here seems to be the problem after a reboot; MM doesn’t exist. Anyone help with that?
                      0_1489399154131_upload-11cdce11-27e8-4035-ace2-552205eb0546
                      • M
                        mortenbirkelund
                        I think the reason why you get the “MM doesnt exist” error is just because the script isnt running.
                        You are asking pm2 to show you status of a process that doesn’t exist. So this error is not the problem, but just a symptom of the fact that pm2 doesnt start mm.sh after reboot as it should. . Hope that makes sense.
                        From what i can see on your screenshots, you seems to be doing it correctly so i dont know why pm2 will not start mm.sh for you. Sorry
                        • R
                          robiv8
                          I have the same problem after a new Installation.
                          I do all how is documented in the Auto Starting MagicMirror GitHub Page
                          Any help will be nice :-)
                          • R
                            robiv8
                            OK for all newbies and dummies like me ;-)
                            The ‘pm2 startup’ on the beginning is very important !!
                            • C
                              Charley Module Developer
                              With the pm2 startup you are not ready.
                              Read the output and copy and paste the command that is the most made mistake.
                              MMM-Bose-Soundtouch, MMM-Domoticz, MMM-crypto-portfolio, MMM-Fibaro, MMM-rain-forecast
                              R 1 Reply Last reply
                              • R
                                robiv8 @Charley
                                @charley
                                Maybe you are right!
                                But for me that was the reason wy it is not starting. I forgot this at first. ;-)
                                Of course you should do everything in order. Then it works.
