    start on reboot
    14 Posts 6 Posters 9.4k Views 5 Watching
      Bu52
      I would like to have npm start executed upon reboot. I’ve gone through every line of the install procedure (which is very good, BTW), but I have to manually open a terminal window from the gui and then cd HOME/MagicMirror and then npm start. This works fine. But how do I get it to do it automatically upon a reboot?
      • KirAsh4K Offline
        KirAsh4 Moderator
        I didn’t get a chance to write that part yet, however it is (also) documented on the wiki:
        https://github.com/MichMich/MagicMirror/wiki/Auto-Starting-MagicMirror
          Bu52 @KirAsh4
          @KirAsh4 Thank-you for adding to my knowledge again!!
          • KirAsh4K Offline
            KirAsh4 Moderator
            Part of the reason for the auto starting is that occasionally, npm will die, and having the auto restart will take care of that as well.
              Bu52 @KirAsh4
              @KirAsh4 Well, it must be working well because it has been 12 hours and it is still going strong. However, I don’t know how many times pm2 had to restart it. Either way, my perception is that it is working fine. Thanks again.
              • KirAsh4K Offline
                KirAsh4 Moderator
                Log into your rpi and execute 'pm2 list' to list all running pm2 tasks. If you have a bunch of them, then add the task name, like 'pm2 list <TASK NAME>'.
                If you want more info on a specific task, execute 'pm2 show <TASK NAME>'.
                You’ll get info screens like this:
                X 1 Reply Last reply Reply Quote 0
                • X Offline
                  xbmcnut @KirAsh4
                  @KirAsh4 Thanks for the screenshots. I’m having trouble with mine starting after a reboot too and when I run pm2 list, it does not show a PID even though MM is working. Is that why it won’t start on reboot?
                  0_1489397924822_upload-5ea2ce1a-ac9b-46bf-b907-33133f2ff9ac
                  • X Offline
                    xbmcnut
                    OK, did pm2 restart mm and now have a better result. Am I right to issue pm2 save after that?
                    0_1489398453521_upload-00e37575-c508-4665-b348-1be887be8cb0
                    • X Offline
                      xbmcnut
                      OK, here seems to be the problem after a reboot; MM doesn’t exist. Anyone help with that?
                      0_1489399154131_upload-11cdce11-27e8-4035-ace2-552205eb0546
                        mortenbirkelund
                        I think the reason why you get the “MM doesnt exist” error is just because the script isnt running.
                        You are asking pm2 to show you status of a process that doesn’t exist. So this error is not the problem, but just a symptom of the fact that pm2 doesnt start mm.sh after reboot as it should. . Hope that makes sense.
                        From what i can see on your screenshots, you seems to be doing it correctly so i dont know why pm2 will not start mm.sh for you. Sorry
